dakota lifted with coil over
Old 09-05-2010 | 02:26 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Honestly, Im suprised that one of you guys havn't tried to fab up a diff drop yet. Usually the mild kits are simply longer bolts, and billet or steel spacers, that lower it down an inch. Also, I'm suprised no one has bit the bullet and purchased the control arms from chassis tech, $500 gets you two longer upper arms that are supposed to be able to handle up to 6" of lift. They also take a bolt on ball joint from a chevy that works with our knuckle.
The lower control arms we have could probably handle a lot of lift before not being able to work anymore. Just have to flip that tie rod.
Someone do it already lol.
  #32
Old 09-05-2010 | 04:49 PM
sullysdetailing's Avatar
sullysdetailing
I have a question the Chassis Tech kit only makes the the upper control arm longer, If you mod the lower control are longer and add longer cv's would that make the kit safe?
