HHR Fan Installed
Old 09-11-2010 | 05:47 PM
Blown287's Avatar
Blown287
Sounds awesome man, if you get the chance please throw up some pics. I have brackets I just haven't shaped them or painted them yet.
Travis and I spend the day repairing my exhaust system, lol. I've starting tuning the alcohol injection again and broke a header bolt as well as warped both flange bolts on the driver side. The 1st week of October Trucky and I have appointments at a local race shop to have solid engine mounts made
  #122
Old 09-12-2010 | 02:32 AM
ozone45212's Avatar
ozone45212
Default Fan Shroud
Zip tied my factory shroud back on behind my HHR fan today. If it seems like it actually helps the temp, I am going to fab up some brackets.
  #123
Old 09-12-2010 | 02:54 PM
Blown287's Avatar
Blown287
Thats good news. The HHR fans are great and I'm really impressed with them. I laugh every time I watch the temp gauge get up to 1/4 and drop back down to 1/8, lol
  #124
Old 09-13-2010 | 12:53 AM
ozone45212's Avatar
ozone45212
Your temp gauge drops back to 1/8? mine seems like it stays about 1/4 - 5/16 after warming up... 'course you have the 4.7 with a totally diff set up. I only have the 3.7. A little warmer than with my clutch fan.
  #125
Old 09-13-2010 | 12:59 AM
Blown287's Avatar
Blown287
Unless I'm running the AC then the temp will stay at 1/4. If I make several WOT runs back to back that will do it also. The rest of the time it will climb to 1/4 then drop back to 1/8, lol. I love it.
  #126
Old 09-13-2010 | 01:04 PM
newmexicoram's Avatar
newmexicoram
Blown,
Tried to take a picture but then turned out awful. Anyway... Of course my temp. needle doesn't run anywhere as low as yours. If I remember correctly you are running a high performance water pump. Could that be the reason? Or could it be just the region. Our summer temps'. are usually between 90-98 degrees of dry heat. Boy if my temps. ran as low as yours I would go get me the 18' camping trailer I've being eyeing.
  #127
Old 09-13-2010 | 02:07 PM
Blown287's Avatar
Blown287
No doubt the water pump could be part of it. It never ran this cool before but I'm certainly enjoying it.
  #128
Old 09-13-2010 | 03:14 PM
hendrixx324's Avatar
hendrixx324
I ended up puting my clutch fan back on because i ran hot. it runs ok now with the clutch fan but i allready miss the power
  #129
Old 09-13-2010 | 03:32 PM
Blown287's Avatar
Blown287
hendrixx, I know you talked about the SPAL did you ever get one? I ask because I'm curious if the fan was running in both high and low speeds or just low speed?
Its important because these fan are successfully used on some major HP producing applications.
http://www.cuda-challenger.com/cc/in...?topic=59157.0
  #130
Old 09-13-2010 | 04:28 PM
trucky's Avatar
trucky
Originally Posted by newmexicodak
Blown,
It is NOT because of the region. We had a hot humid summer and my truck was always around just below half. Of course my E-fan situation is on the fritz, still working on it. But I am thinking his water pump has really helped.
Quick Reply: HHR Fan Installed
