Pulling The Heads
Old Jul 23, 2010 | 02:44 PM
  #71
rengnath's Avatar
rengnath
Sweet! Good luck and keep us updated!
Old Jul 23, 2010 | 03:04 PM
  #72
Dakkkota's Avatar
Dakkkota
Default looks good
but aluminium is so soft i hope you did'nt scratch the head or block because i assume you wont have them planned. and for boost application between intake and heads go with that super sticky GASKET sealer hi temp on both side of intake gasket we had major leak between intake and heads with 11psi and be 100% sure you dont rotate the valves while changing the springs if you dont lap them. And i own Behives springs those spring are fun because they dont need machining to head but they tend to break on top result dropping the valve...(happens ofter with GM LS serie and old school 350)
Old Jul 23, 2010 | 03:24 PM
  #73
Blown287's Avatar
Blown287
http://www.hylomarblue.com/technical_data.htm
Old Jul 23, 2010 | 05:14 PM
  #74
Dakkkota's Avatar
Dakkkota
Default ok
this should do it!
Old Jul 23, 2010 | 10:52 PM
  #75
Blown287's Avatar
Blown287
Got the first JBA header painted with the high temp exhaust paint.
Old Jul 24, 2010 | 07:41 PM
  #77
Blown287's Avatar
Blown287
I will see how the paint holds up. If it doesn't I might look into the ceramic coating. I got the manifold painted today.
Old Jul 24, 2010 | 11:29 PM
  #79
trucky's Avatar
trucky
I'm trying to get him to take my 69mm fastman TB but he doesn't believe in bigger TBs lol. He has his reasons though and he will try it so at least he is open minded. I just got a 72mm F&B for uh... an experiment?
Old Jul 25, 2010 | 12:00 AM
  #80
Blown287's Avatar
Blown287
Travis, well see man. I told you i would at least try it out
