Air intake Custom Resonator ?
Air intake Resonator Customization ?
Hi:
Does anyone has try to customize the air intake resonator?
This plastic box absorb the noise from the engine also restrict the air flow and if you take a serious look it decrease in size inside.
I have a few ideas but I don't know if they really works:
1. Fill the holes inside that cut the noise and restrict the air it will help to give more engine sound and more air flow as well.
2. Another idea was to cut all this curve and replace it with 3'' pvc pipe, then glue it to the resonator to make it look stock as possible. After this use the regular filter box with a K&N OEM style filter, this will suck fresh air from the fender, looks stock (but isn't) and I think It will help to sound more aggressive than the stock uncustomize black resonator!!
What do you think?
Any comments or advice?
My last truck was a Chevy Colorado and many people used to customize the air resonator, it really make it sound different...
Victor
What do you think?
Victor
Hi:
2. Another idea was to cut all this curve and replace it with 3'' PVC pipe, then glue it to the resonator to make it look stock as possible. After this use the regular filter box with a K&N OEM style filter, this will suck fresh air from the fender, looks stock (but isn't) and I think It will help to sound more aggressive than the stock customize black resonator!!
What do you think?
Victor
What do you think?
Victor
Quite honestly, I don't notice much of a difference in engine noise with this at all. Some claim to have gained MPG with theirs, but mine has pretty much stayed the same. Only time I really notice anything is at wide open throttle. You could do as you said and make one yourself with PVC. You might try finding a used Jr. like I did. They are the same for the V6 and the V8. At least on the 05-07. I assume yours is the same.
I think it looks good without the resonator box. I kept the factory box in case I ever sell the truck and the new owner wants a factory look.
Like any mod you do, beauty is in the eye of the beholder. Good luck with it.
I just saw you have a 2010. How do you like it so far? I am just getting used to the front end change from the 05-to 07.
Victor, check this thread out. Exactly what you are looking for:
https://dodgeforum.com/forum/3rd-gen...ir-intake.html
Ya beat me to it...
I read the post and just laughed thinking he's looking for exactly what I did to mine.
Hey Victor, if you open the stock airbox there's also a baffle in there that can be removed to increase airflow.
You can add a K&N filter to the stock box and then cut the air nozzle down(inside the air filter box) that comes from inside the fender to eliminate the restriction to the flow coming from the fender. You can't do much about the increasing and decreasing diameters going in and out of the box but you can make gains with the stock box. I would epoxy over the holes - 1 on the bottom of the intake tube coming from the fender and 1 in the tube just before it gets to the throttle body. These deaden the sound. Just my thoughts, you may do something different.
Trending Topics
You can increase the intake side of the box...
I would also recomend drilling a small maybe 1/4 inch hole in each corner of the stock box. in the case of water getting into your airbox, this will let it drain properly.
