Deep Transmission pan
You can even ones that have fans built in, and then you could mount it pretty much anywhere and not risk blocking your radiator.
http://www.jegs.com/i/JEGS+Performan...60346/10002/-1
Sorry to Burst your bubble guys, but that tube is the Power Steering Cooler.
The Transmission cooler is built into the bottom of the Radiator.
Originally Posted by mopar!
i don't know if my truck has the towing package or not.
https://dodgeforum.com/forum/3rd-gen...ild-sheet.html
and yes I thought it was either the tranny or p/s cooler cause you get those with the trailer tow group. My build sheet says auxiliary transmission cooler and power steering cooler. So somewhere there is an aux. tranny cooler....cause they would not call the main cooler and aux cooler....or would they???
Here is a deep tranny pan. They make 2 a deep and an extra deep. I'm sure if you call them they will give you the dimensions so you can check to see how much clearance you will need.
http://mrtruck.net/pml.htm
