Deep Transmission pan
Well you can always look at another option. A pan will add about 3-4qts of capacity. If you do an external transmission cooler, you probably could add atleast 2-3qts depending on how big the cooler is and how much additional line there is, and if you choose to do another filter or not.
Heat is the major component of failure for transmission fluid, so a cooler would be a good option to look in to, IMO.
I havent installed one, but I think DodgeTrucker has. All you do is tap in to the stock trans cooler lines that run to the bottom of the radiator. You should be able to mount it right in front of the radiator. You can get the factory option trans cooler which mounts in front of the radiator, but an aftermarket would probably serve you better.
Trending Topics
Thats it. Classy Chrysler at its best right there. Lol
Heres an example of something on the aftermarket side that would hold alot more fluid and do a better job cooling:
http://www.jegs.com/i/Flex-a-lite/400/3826/10002/-1
