H/O heads
Old Jan 26, 2011 | 12:08 PM
  #31
ruger226's Avatar
ruger226
Originally Posted by thunder98110
i just got off the phone with crane cams. they do regrinds for 206 cams for 289 bucks.
Do they regrind non h/o? because i thought they started with h/o cams to get 206 212 212x...
Old Jan 26, 2011 | 12:11 PM
  #32
thunder98110's Avatar
thunder98110
i told him i had non ho cams and wanted 206 (i dont but just acted like i did)
Old Jan 26, 2011 | 01:03 PM
  #33
Blown287's Avatar
Blown287
You can have a standard 4.7L cam reground, but you won't get the same performance out of it. The standard cam and HO cam have the same lobe profiles but different centerlines. The HO will be on a 111 centerline and the stock cams are a 115 centerline. This is why we wanted billet cams with true centerline to spec vs regrinds on 115 centerlines.
Old Jan 26, 2011 | 02:37 PM
  #34
thunder98110
oh that sucks. so would it be even worth it to regrind a standard 47 cam?
Old Jan 26, 2011 | 08:20 PM
  #35
Blown287's Avatar
Blown287
I don't think so but who knows, a 212X grind on a standard 111 centerline profile might not turn out bad. Personally, I wouldn't spend the money on a non ho for a grind.
Old Jan 26, 2011 | 08:24 PM
  #36
thunder98110
billy dropping knowledge bombs! well thats good to know, thanks. i was going to give my standard cam to a friend but maybe not anymore.
Old Jan 27, 2011 | 07:28 AM
  #37
ruger226's Avatar
ruger226
So can they make a 212x from a h/o?
Old Jan 27, 2011 | 09:05 AM
  #38
Blown287's Avatar
Blown287
From an HO core they can make 206, 212, 212X, 218 and 224. Currently the only performance cams available to us are regrinds based off of the HO 115 centerline core.
That is why Billet camshafts would be the bomb vs the regrinds we've been using.
Old Mar 23, 2019 | 04:57 AM
  #39
D-Lab3's Avatar
D-Lab3
I would like to get some dome pistons but thats more time and money that i dont have. I cant have any down time because my truck is my only vehicle so i would have to buy a used motor tear it down and build it. For now im just looking for a set of used heads so if anyone can find a set for under $500 please let me know.
pick n pull. They are half that if you don't need accessories
Old Mar 23, 2019 | 05:25 AM
  #40
D-Lab3's Avatar
D-Lab3
I was lookin at the cometic gaskets so i guess there gonna have to be on the parts list. Im gonna talk to my neighbor to see if he knows anyone who does head work befor i pay to ship them. He had a 9sec pinto so im sure he does.
How much do you think you would have to mill down to get 10.0 to 1 CR?
All of the OEM head gasket companies strongly warn against milling more than .002 due to ohc timing issues.
