radiator fan never shuts off??
Old Jan 26, 2011 | 10:37 AM
evoviiijeremy's Avatar
evoviiijeremy
Default radiator fan never shuts off??
  1. I have a V6 and I noticed the truck never really reaches full operating temp. But I also noticed the radiator fan never shuts off. Correct me if I am wrong but shouldnt that be cycling. Mind you it is 10 degrees here too so in theory it should almost never run. Can someone chime in here please so I dont look like a complete moron going into the dealer.
Old Jan 26, 2011 | 10:39 AM
evoviiijeremy
Also when i say never shuts off i mean while the truck is running.
Old Jan 26, 2011 | 10:45 AM
Does the V6 use the same fan clutch as the V8's? If so, could the fan clutch be bad? What year and how many miles on it? Welcome to the forum by the way!
Old Jan 26, 2011 | 10:56 AM
evoviiijeremy
thanks. it is a 07 with 48k on it. I took it to the stealership and they said it is mechincal and it never shuts off and the truck is running at normal temp. I have never heard of a fan doing that ever.
Old Jan 26, 2011 | 11:05 AM
well theres always the e-fan swap. unless it's under warranty.
Old Jan 26, 2011 | 01:19 PM
evoviiijeremy
Its under warranty. I was just wondering if everyone else's trucks do the same thing
Old Jan 26, 2011 | 01:23 PM
I have not heard of it since I've been here (Last April).
Old Jan 30, 2011 | 05:48 PM
FrenicX's Avatar
FrenicX
So your temp gauge doesn't make it to the middle? Mine warms up just fine and I have had some killer cold days out here. I can hear my fan sometimes after starting up but the sound will quiet down after a couple miles.
I had a fan clutch temp coil (dunno what it's called) rust up once and cause the fan to be stuck half way engaged. But that was on my 18 yr old Ranger. But all I did was soak the coil with PB blast and it started working again.
EDIT:
Here's some info that might help you.
http://www.aa1car.com/library/cooling_fan_clutch.htm
Talks about the fan clutch only, but when reading it I noticed it says that some clutches are designed to stay engaged to help the engine warm up faster... once it's warm it acts as normal. If your not reaching full operating temps then your clutch might stay engaged to keep drag on engine to try to warm it up. Might mean you actually have a stuck thermostat or something.
Old Jul 12, 2011 | 06:26 PM
08_Dakota's Avatar
08_Dakota
I have an 08 Dakota SXT V6 4X4. My rad fan runs all the time as well. It also never reaches the normal half way temp. Which I am assuming is not a bad thing. I am in Ontario Canada and its really hot summer right now. Just got the truck last month. Its awesome
Old Jul 12, 2011 | 07:25 PM
thunder98110's Avatar
thunder98110
could be a stuck thermostat.
