Home made air intake
Old Jan 27, 2011 | 06:33 PM
marcsnyder05's Avatar
marcsnyder05
Default Home made air intake
Here are some pics of my new intake I built. I was really easy to do and cost about $80.
Here I had to splice in some more wire to this sensor
Valve cover breather with it's own filter
Old Jan 27, 2011 | 06:45 PM
jnd03's Avatar
jnd03
can you post what parts did you use and where did you get them?
Old Jan 27, 2011 | 06:56 PM
marcsnyder05
I used a 90 degree, 60 degree, a 2' x 3" pipe (all ABS pipe) a heat duct clamp and ABS glue from Home Depot a grommet kit and extra hose clamps from Checker the filters I got at auto zone the rubber sleeve I have to order from spectre needed a 4" one and I couldn't find a store that had a 4" only 3"
Old Jan 27, 2011 | 07:00 PM
jnd03's Avatar
jnd03
can you tell a difference in performance?
Old Jan 27, 2011 | 07:03 PM
marcsnyder05
oh yeah it got more ***** and it's a lot LOUDER!!
Old Jan 27, 2011 | 07:32 PM
rengnath's Avatar
rengnath
Looks good Marc!
The intake definetly makes these engines louder .... in a good way. Before I got my intake, all I had was an exhaust and I could hear it pretty well at WOT. Now with an intake, all I hear is the engine roaring.
Old Jan 27, 2011 | 07:40 PM
marcsnyder05
Originally Posted by rengnath
Looks good Marc!
Thanks. mine starts to roar at about 2500rpms and just gets louder till about 4600 or so
Old Jan 27, 2011 | 09:42 PM
here's another one of those Bobby, is having a 4" pipe any better than a 3" ??
Old Jan 27, 2011 | 09:48 PM
rengnath's Avatar
rengnath
Well, let me explain:
If you're in to fatties, I recommend a 4" pipe minimum.
A 3" pipe will work, but you aren't going to get much more than a small chuckle because all you will be doing is tickleing her.
A 3" pipe is well suited for all other women. There's a point where big becomes too big...
And on a side note, if you are in to fatties, dont forget to strap a 2x4 (a piece of lumber, not an actual truck) to your back so you don't fall in
Old Jan 27, 2011 | 10:00 PM
I knew I would get a lesson....
