High Output Alternator or Really Bad Electrical System Problem???? PLS READ
Old Jan 29, 2011 | 06:06 PM
kwanczyk's Avatar
kwanczyk
Exclamation High Output Alternator or Really Bad Electrical System Problem???? PLS READ
i have noticed that factory with nothing additional hooked up my battery, when i have the dome light on at night and turn the turn signal on, the dome light flashes with the turn signal??? that is a really weak electrical system... is there any advice that you may have or suggestions for a fix.
thanks
Old Jan 29, 2011 | 06:24 PM
hendrixx324's Avatar
hendrixx324
my truck does that too. you ccould get a higher amprage alternator or mayube a higher amprage battery, I think.
Old Jan 29, 2011 | 06:26 PM
rengnath's Avatar
rengnath
Mine does the same thing ..... seems normal to me, not a faulty alternator.
Old Jan 29, 2011 | 06:35 PM
kwanczyk's Avatar
kwanczyk
i have an optima yellow top battery... so its not that
it doesnt seem like it 'should' be normal...
Old Jan 29, 2011 | 06:38 PM
Blown287's Avatar
Blown287
Do you have a multimeter? You can check it and see if it's having issues. If you want a better alternator get the 160 amp.
Here you go.
https://dodgeforum.com/forum/3rd-gen...-is-dying.html
Old Jan 29, 2011 | 06:40 PM
kwanczyk's Avatar
kwanczyk
ill do it today or tomorrow and tell you what it reads..
Old Jan 30, 2011 | 07:24 AM
VConfreda's Avatar
VConfreda
How about getting a large capacitor and hooking it up to the battery. that way it helps stabilize the voltage?
Old Jan 30, 2011 | 06:27 PM
kwanczyk's Avatar
kwanczyk
Default cap
how many farads are we talking?
Old Jan 30, 2011 | 06:40 PM
Eimer123's Avatar
Eimer123
1.21 jigawatts should do.
Old Jan 30, 2011 | 07:06 PM
rengnath's Avatar
rengnath
A flux capacitor should do the trick nicely! Gun that bad boy up to 88!
Heres one for only $45,000 .... (power source not included of course)
http://store.zeckhausen.com/catalog/...zmap=FC.121.99
