Cold air intake pipe with factory air box
Old Feb 14, 2011 | 04:46 PM
mxstar21's Avatar
mxstar21
Originally Posted by eaglescanfly
Thanks lol..... Hey the pipe I got with the kit. The whole cheap kit u can get it for 28 dollars us. Free shipping in the states. the intake pipe in the kit has a hole for the sensor. Than I had to cap off the extra vaccum hole on the pipe as my oem air box has one.
http://cgi.ebay.ca/DODGE-DAKOTA-3-7L...item5d2c76da5d
The first thing I had to get after getting the pipe was an adapter to slide into the oem flex hose off the air box. 3inch to 3inch adapter I got from lowes. Both ends come with the strap to tighten it. So I had to take one end off as it was going to slide into the oem flex hose. On the end of the new air intake pipe I slid the extra rubber adapter that comes in the kit. To make a tight seal. In all it was cheap to do this mod.
Any chance you could post a close up pic of where the air temp sensor mounts? I will have to make something for mine. The kit I bought looks pretty close to yours, and was the same cost. I am also not sure what the smaller diameter short piece of hose is for.
http://cgi.ebay.ca/AIR-INTAKE-FILTER...ht_2758wt_1139
Old Feb 14, 2011 | 05:05 PM
Here is the kit installed on mine. You can see the AIT plugged in on the right side just before the TB. I bought an extra 6" long piece to extend the filter further away, so it it right up next to the existing hole in the fenderwell that the original box drew air from.
Old Feb 14, 2011 | 05:31 PM
mxstar21's Avatar
mxstar21
Nice. Looks good! Looks like my kit, I just don't have the hole. I am going to send an email to the place I got it to see what the deal is.
Old Feb 14, 2011 | 05:37 PM
eaglescanfly's Avatar
eaglescanfly
Hey sorry for the late post was working lol.......
Here are my pics.... and the newest thing I did was temporary put a pipe from the air box to the fender where the hole is. It sounds a little better with out the air horn lol...... One of the pics is the air temperature sensor spot.
Old Feb 16, 2011 | 12:29 AM
Fitz-C's Avatar
Fitz-C
i have the same kit, i just stuck a K&N filter on the end instead of that chepo one they gave with it. air intake temps are about 7-14 degrees (Celsius) cooler than with the stock.
i also removed the front air dam dohicky
Old Feb 16, 2011 | 12:32 AM
hendrixx324's Avatar
hendrixx324
I dont see to many yellow dakotas it looks nice
Old Feb 16, 2011 | 01:39 AM
Ueland's Avatar
Ueland
Damn that looks really farmiliar..
https://dodgeforum.com/forum/3rd-gen...ir-intake.html
Here's what it looks like in plastic....
I measured my ouside air temp vs my intake air temp with the SC. I'm withing 15-20 degrees as long as I'm about 35mph and even more when under full load. I'll be doin a few other tricks to see if I can get the temps even closer....
Old Feb 16, 2011 | 06:47 AM
06Dak4.7Silver's Avatar
06Dak4.7Silver
whoever this is above me with the airaid tube and k&n filter in the stock airbox we did the same exact intake. only difference is that you changed out this "air horn" can i have a dimension for that little piece of hose you guys used to connect to the fender?
Old Feb 16, 2011 | 11:43 AM
gjmoran's Avatar
gjmoran
looks like 3 inch flex tubing
Old Feb 16, 2011 | 12:18 PM
rengnath's Avatar
rengnath
This is mine:
Its all about getting that cool air to the box
