Click in steering wheel
Old Mar 20, 2011 | 01:50 PM
  #21
BAdassR/T's Avatar
BAdassR/T
Ok I finally got around to checking out this shaft. Is it suppose to be easy to move the shaft with the truck off and on the ground ? Mine moves very easy. Almost to easy. Whats your take on that. I have not yet tried to listen to the creak but I'm sure it can't be far off from that pos shaft
Old Mar 20, 2011 | 02:45 PM
  #22
Eimer123's Avatar
Eimer123
Can you explain further what type of movement you are having? I still have my old shaft I took out and still have not got around to seeing what part failed. My guess is the rubber ring that is riveted on is the failing point
Old Mar 20, 2011 | 04:19 PM
  #23
BAdassR/T's Avatar
BAdassR/T
Well, truck seems to wander all over the road, tie rods are new, have a slight vibration, that I think is the rotors which im replacing. Steering has alot of play in it. When you turn the steering wheel on a slight upward hill the steering creaks. Not sure what else but really annoying
Old Mar 21, 2011 | 06:53 PM
  #24
BAdassR/T's Avatar
BAdassR/T
The shaft would make the steering erratic wouldn't it? I'm just looking for answers without starting a new post
Old Mar 21, 2011 | 06:57 PM
  #25
rengnath's Avatar
rengnath
If the steering has play in it, Im guessing thats your steering shaft. Can you have someone get in the truck and turn the wheel for you, while you go under the hood and hold the shaft to see if thats the problem?
Old Mar 21, 2011 | 07:59 PM
  #26
BAdassR/T's Avatar
BAdassR/T
I can, but how would I tell if it's def it? I'm fine with replacing it, I just want to make sure. It looks like hell under there also so rusted everything else is nice and black. If I go under the hood I can easily turn the shaft by hand.
Old Mar 21, 2011 | 08:07 PM
  #27
rengnath's Avatar
rengnath
If you can hold the shaft in one position, and someone can move the wheel, the shaft is bad.
Old Mar 21, 2011 | 08:13 PM
  #28
BAdassR/T's Avatar
BAdassR/T
Alright def gonna test this out, I'll let ya know how it goes most likely this is the problem and I can just go ahead and buy it.
Old Mar 21, 2011 | 08:14 PM
  #29
rengnath's Avatar
rengnath
Let us know man! Good luck!
Old Mar 22, 2011 | 08:13 PM
  #30
BAdassR/T's Avatar
BAdassR/T
just a quick question where did you find these bolts
M10x1.50x39.00
