Click in steering wheel
Old Mar 22, 2011 | 08:50 PM
  #31
rengnath's Avatar
rengnath
I didnt find them yet. The hardware store should have them though, or no?
Old Mar 22, 2011 | 09:30 PM
  #32
Eimer123's Avatar
Eimer123
Originally Posted by BAdassR/T
just a quick question where did you find these bolts
M10x1.50x39.00
I bought my bolts at the hardware store, the dealership will carry them also, the bolts can be longer, they will not contact anything. Ace hardware is where I found mine
Old Mar 22, 2011 | 09:36 PM
  #33
BAdassR/T's Avatar
BAdassR/T
Alright thanks that's easy Enough wasn't sure if it had anything special to it.
Old Apr 12, 2011 | 04:29 PM
  #34
rengnath's Avatar
rengnath
Im bringing this one back to the top. The click in my steering wheel has become more apparent so I am swapping it out this weekend. I was originally going to order it offlline for $164, but Im not to sure about the place where its coming from. The cheapest I have found it from reputable online sources is about $182. Im buying it locally from the dealer for $218 because I want to do it when the parents are out of town this weekend so no time for shipping.
I got new bolts from the hardware store; they are 1mm longer than stock. Im not sure if they will work or not because the threads dont go all the way to the heads, but Im sure it will be fine.
Good news though. I can access both bolts from up top; no need to get on the old back or cut out my wheel well. You need to have the wheels off the ground so you can turn the wheel to gain access to both bolts. I was able to get in there with my 13mm socket and 1/2" drive snap on ratchet no problem, and I was able to turn both bolts. I gave them some penetrating lube and tightened them back up. Should be an easy swap. If I could use the impact, it would probably go really quick but I dont think I can wedge it in there. Ill keep you guys posted.
Old Apr 12, 2011 | 05:37 PM
  #35
This is the intermediate shaft, right?
Old Apr 12, 2011 | 06:57 PM
  #36
rengnath's Avatar
rengnath
Yup, the lower intermediate shaft. If you pop the hood and look right below the brake booster, its the black shaft that sits on an angle.
Old Apr 12, 2011 | 06:59 PM
  #37
good luck with the install...your on your way to a whole new truck...lol
Old Apr 12, 2011 | 07:14 PM
  #38
rengnath's Avatar
rengnath
Practically. Not much more to do after this. I need a new serpentine belt because mine makes a little noise, but if Im going to d that, I probably should just do an e-fan
And lets not forget, a Hiptek throttle body and bigger injectors!
Old Apr 12, 2011 | 08:39 PM
  #39
Eimer123's Avatar
Eimer123
Those bolts will work just fine, they do not need to be threaded the entire way.
Old Apr 12, 2011 | 08:43 PM
  #40
rengnath's Avatar
rengnath
Alright, sweet. Thanks Reid. I'm planning on either doing it Friday night or Saturday afternoon
