what else could go wrong???
Old Apr 3, 2011 | 04:41 PM
hendrixx324's Avatar
hendrixx324
Angry what else could go wrong???
Old Apr 3, 2011 | 04:56 PM
ruger226's Avatar
ruger226
Please tell me that happened during the install and not the test drive?
Old Apr 3, 2011 | 04:59 PM
hendrixx324
it happend when i started her up there all the exhaust valve rockers so i think when it had a huge backfire it broke them
i did i cyliner leakage test and it was fine idk how nuthin else got F'ed up
Old Apr 3, 2011 | 06:44 PM
jnjinfla's Avatar
jnjinfla
Ouch. I would for sure pull the heads and do a check. It is time well spent if there is an issue. Better to check and fix now than later.
Old Apr 3, 2011 | 08:14 PM
hendrixx324
yea maybe i should just pull the head... i got the rockers luckily the dealer had them but im not putting them on untill its timed
Old Apr 3, 2011 | 09:58 PM
Blown287's Avatar
Blown287
Sean I have seen that before on someone else's 4.7L. The rockers slipped off the valve stem and lash adjuster. The installer didn't notice (if you don't pay close attention you can miss it). He started it up, the cam came down breaking the ends off. The pics they emailed to me look just like that.
Just based off the pics it looks like the rockers got trapped off the the stems and were snapped. Eric is right, you need to pull the heads and check the valves and pistons.
Like I said man, before you do anything else, veryify timing. From Travis's motor I can tell you a 4.7l interference motor can still turn over and run with one cam tooth out of time. That should not happen but it did.
Good luck.
Old Apr 3, 2011 | 10:08 PM
hendrixx324
ok ill do that. can you believe i didnt lose any lash caps. i got all of them
Old Apr 3, 2011 | 10:14 PM
Blown287's Avatar
Blown287
That is good news. Sean, last 4 or 5 times we talked on FB I told you to pull that timing cover and set timing, lol. I know for a fact these 4.7Ls will start out of time even though they aren't supposed to. But if the rockers slid out of position, there isn't a sensor to detect it. There is a chance your valves/pistons are fine but you need to check to be sure.
If I were you I would .
1. Pull both heads check pistons and valves.
2. Put the heads back on and replace everything damaged, rockers, etc.
3. When the heads on pull the timing chain cover and reset timing.
Good luck brother.
Old Apr 3, 2011 | 10:26 PM
hendrixx324
yea i plan on pullin the cover and heads tomorrow... check everything and getting it all back together by tuesday.
