Another cold air intake to look at
Old Apr 4, 2011 | 03:28 PM
MitsuRaider's Avatar
MitsuRaider
Default Another cold air intake to look at
So I started with the AEM kit, and it made for a very clean and easy install.
I noticed right away that the metal intake pipe gets REALLY hot while the engine is operational so I improvised some insulation.
I used gorilla tape, pretty tough.
And finally widened the hole where the "train horn" intake piece breathes through.
And i gotta say I am VERY impressed with results. Engine now growls under acceleration and performance gain can be felt a bit.
Old Apr 4, 2011 | 03:58 PM
that looks very nice. is that gorilla tape made for high temps?
Old Apr 4, 2011 | 04:02 PM
MitsuRaider
honesty I couldn't find any high temp reference on it but its been fine so far, the tape is very thick.
I will post any engine fire pics, lol
Old Apr 4, 2011 | 04:06 PM
Dakkkota's Avatar
Dakkkota
you should remove the aem brute force plate and glue it on the tape!!
Old Apr 4, 2011 | 04:13 PM
MitsuRaider
Ha ha, its funny that u said that because that's exactly what I did right after I taped it. I just ended up taking it of
Old Apr 4, 2011 | 11:24 PM
thunder98110's Avatar
thunder98110
lol. black absorbs all energy equally= gets hotter than any other surface color. thats why i wrapped my intake tube in aluminum foil=reflects all energy equally. think about putting tin foil in the oven you an remove it w.o a glove.
Old Apr 5, 2011 | 12:02 AM
cheeseburger's Avatar
cheeseburger
he has a point.
Old Apr 5, 2011 | 12:51 AM
FrenicX's Avatar
FrenicX
Originally Posted by cheeseburger
he has a point.
Aluminum also conducts thermal energy aswell. The ideal would be to insulate and then cover with foil. The AEM tube is already shiny after all.
Old Apr 5, 2011 | 12:56 AM
Blown287's Avatar
Blown287
I used this with my ram-air box before the blower and it worked well.
http://cgi.ebay.com/ebaymotors/Cool-...item20a207f201
Old Apr 5, 2011 | 07:37 AM
I'm sure you could use header tape as well.
