I completely flushed my system and put in GM DEX-COOL
You should not add plain tap water into your system, it should be DISTILLED WATER
The Hoat is some stupid expensive organic hybrid.
I would never use anything that says universal.
Remember coolant is like brakes do not cheap out on this. Good brakes makes your truck stop when needed.
Good coolant keeps your entire engine and cooling system in good condition. If you mess it up you can trash the entire engine.
LOL all the horror stories about GM's Dex-Cool i wouldn't even put it in a GM vehicle!!
But each to there own as long as it says for Chrysler you should be ok
And on a side note Mopar coolant is concentrated (you mix it) and its only 5$ more then prestone 50/50
