Old Aug 10, 2015, 06:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Guides
Print Wikipost
Transmission Fluid and Filter change questions...
Old May 3, 2011 | 06:06 PM
Buckmaster's Avatar
Buckmaster
Default Transmission Fluid and Filter change questions...
How many quarts of fluid for a pan drop filter and fluid drain and refill? Mine is a 05 4.7. 4x4.
Also Napa had to order my filter, but seems like when I read various searches of other transmissions, there are "filterS". What does our dakotas have? Thanks guys.
Old May 3, 2011 | 07:02 PM
Eimer123's Avatar
Eimer123
We have 2 filters. A flat pickup filter, and another engine oil looking style.
Old May 3, 2011 | 08:55 PM
i just took mine to aamco. the replaced both filters and whatever fluid was lost. i called a few days before and they had the filters/gasket ready for me when i brought it in. most places wont stock all filters all the time. less than $100 with a coupon. well worth it for me.
Old May 5, 2011 | 04:28 PM
Buckmaster's Avatar
Buckmaster
Any idea on Capacity, I picked up 6 qts....?
Old May 6, 2011 | 09:26 AM
GrnDak01's Avatar
GrnDak01
That should be plenty. I think you'll probably get 4-5 in maybe six. I need to do this to later this spring.
Old May 6, 2011 | 10:27 AM
One way to find out is to catch all that comes out and measure it.
Old May 6, 2011 | 11:01 AM
superdak05's Avatar
superdak05
i went to dodge and had the complete trans axle service done, 299.99, tranny, trans axle, both differentials.
Old May 7, 2011 | 05:53 PM
Blown287's Avatar
Blown287
6qts if you just drop the pan. 14 qts is you drain the cooler, lines and drop the tranny/pull the torque converter and drain it.
Old May 8, 2011 | 10:07 PM
Blu3P0ny's Avatar
Blu3P0ny
I dropped the pan and replaced the filters just last month and it took about 7 quarts to fill it up.
Old May 8, 2011 | 11:27 PM
Buckmaster's Avatar
Buckmaster
Just finished up with it yesterday, I took 7 qts exactly to get it between the marks when hot. Advance auto computer called for 6.5 but it ended up needing 7. Thanks for your help guys.
