Installed Fogs on a 05 ST (Lots of Pics)
Old 07-25-2011 | 05:30 PM
Reject's Avatar
Reject
Originally Posted by cheeseburger
i did the exact same thing months ago. you can use a relay and trigger them with the parking lights. also if ur running aftermarket housing dont forget that you can run chevy high beam bulbs in you fog lights and get more light.
They are the factory type ones off ebay, the kit that comes with a wiring harness and that. They bolt up factory.
I believe they are H10 Bulbs (I bought the Yellow ones for them)
Old 07-25-2011 | 10:16 PM
cheeseburger's Avatar
cheeseburger
so far from what we have been able to figure out, only aftermarket housings can stand up to the heat. oem ones crack. btw yellow bulbs is gonna be sick. think im gonna copy you.
Old 07-25-2011 | 10:23 PM
I ran 100 watt in my fogs for about 3 months (housings bought from rock auto) started to see some burned/melted areas just above the bulb. I went back to 55 watt because I knew it would only be a matter of time before I melted something ans ruined the housing...I have 2500k, 5000k, 6000k and 8500k bulbs....I switch them out every now and then just for something different....
Old 07-26-2011 | 07:18 AM
Reject's Avatar
Reject
I made sure they wernt 100watt, same with my Headlights, they are the normal watts so hopefully no issues.
Old 07-26-2011 | 06:13 PM
Hammond_Egger's Avatar
Hammond_Egger
If you need help getting the switch shipped to Canada, I'd help you!
Just PM me
Old 07-26-2011 | 06:20 PM
Reject's Avatar
Reject
Just PM me
I emailed them to see if they will ship to Canada and what the costs would be.
Old 07-26-2011 | 10:03 PM
thunder98110's Avatar
thunder98110
yellow fogs are the best, mine are the piaa 510's
Quick Reply: Installed Fogs on a 05 ST (Lots of Pics)
