Front sway bar disconnects
Old Oct 1, 2011 | 01:06 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Default Front sway bar disconnects
This has been discussed several times on the lack of availability for off roading components for our trucks. I'm sick of it. Thus, I am going to create a sway bar link that features a quick disconnect system. At first, this seemed impossible based on our configuration. But I just drew up a solution last night. I will need some time to aquire components and test for durability. This kit could potentially double as a factory replacement for daily drivers as well that don't feature the quick disconnect.
What do you guys think? Who's interested? I would like to have a number of potential serious buyers, just so I can get an accurate price from vendors on bulk discounts and what not.
Old Oct 2, 2011 | 07:23 AM
Dakkkota's Avatar
Dakkkota
toyota disconnect should be a direct fit for us
Old Oct 2, 2011 | 10:32 PM
donkeypunch
King Jackass
They are not a "direct" fit at all. Not really sure where you came up with that. But, the design is similar to what I have in mind.
Old Oct 3, 2011 | 09:23 AM
sparks1032's Avatar
sparks1032
I would be interested in it fixing the bushings durability problem more than the disconnect I am on third set of bushings
Old Oct 6, 2011 | 10:50 PM
donkeypunch
King Jackass
Ok guys, good news. I've found the rod ends that I'm going to use, and I've developed a very inexpensive way to complete this. It won't be as pretty as the other stuff that is out there, but very funtional. I will try and get some of the peices in and get photos soon.
Old Oct 7, 2011 | 07:01 AM
Dakkkota's Avatar
Dakkkota
good!!
Old Oct 7, 2011 | 09:00 AM
donkeypunch
King Jackass
How many miles do you have on the truck? I'm at 106K with the original bushings from the factory. How are you going through sets so damn fast?
Old Oct 7, 2011 | 03:48 PM
sparks1032's Avatar
sparks1032
Barely 70,000 and all the bushings and sway bar stuff was done under warranty! The best part is I was in last week with the typical rattling and bumping noise and the said all it needed was a tightening of the sway bar and a week later the rattle is back! I have seen the issue a few times on the forum and for all the BS with these I have not even had the truck off road, for all intensive purposes it is on road all the time with a little bit if towing.
