Moorree Power!
Old 01-31-2012 | 10:36 PM
geofft225's Avatar
geofft225
Yeah Designer, started with flowmasters and a CAI but wanting to move on, ive looked into the hipotek throttle body just never had time to order it. thats probably what im going to go with. Also what all do i need to change axle gears?
Old 01-31-2012 | 10:46 PM
Designer's Avatar
Designer
What gears are you currently running?
varnerhba's Avatar
varnerhba
get a currie 9 inch ha
Old 02-01-2012 | 02:36 AM
FrenicX's Avatar
FrenicX
Originally Posted by Designer
Hipotek throttle body, just put mine on and the response is good. Ordered a sonnex and will eventually get a super chip. Really turned this HO V8 loose. Makes me wonder if the 70mm TB would of been better? My plan was start with the cheap changes and increase til I get where I want.
I have heard going to a 70mm from a 68.5 yields just a 2-2 increase or so, but burns more fuel than what would make it worth it. I imagine a custom tune from hemifever might make those gains higher or If someone were boosting I could see needing as much flow as you can get.
Old 02-01-2012 | 01:14 PM
geofft225's Avatar
geofft225
uhh i never really checked but what ever is stock with 07' v8 mag.
Old 02-01-2012 | 06:20 PM
superdak05's Avatar
superdak05
lets see, I went with the 206 cams, and a hemifever tune, 70 mm throttle body, 4.10 gears, 3 inch single catback, 2800 stall, 125 shot of hemi nitrous, larger y-pipe, 180 thermostat, and I relocated my iat sensor, k/n cold air intake. thats about it,.
Old 02-01-2012 | 09:16 PM
Designer's Avatar
Designer
I would say your running 3.55. Im running 3.92 and get around 16mpg. But with the addition of he hipotek an unexpected side effect is 17mpg mostly highway.
Old 02-02-2012 | 10:32 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I would agree, most likely 3.55s
Quick Reply: Moorree Power!
