can i do this
Old Feb 23, 2012 | 03:33 PM
norma jean's Avatar
norma jean
Default can i do this
with the hids coming, they have no high beams, i plan on using my hellas as a high beam. with the hids turning off when the high beams are hit on the stalk. is it possible to have the low beams kept on when i hit the stalk and the hellas turn on. for example, i hit the stalk for high beams but it doesnt affect my headlights only my hellas. and then hit it again and have the hellas turn off. is this possible? or is this out of my league?
be honest
Old Feb 23, 2012 | 03:40 PM
kbond's Avatar
kbond
be honest
i think its totally possible. you have three prongs on your headlight socket. have one for ground, one for lowbeam one for highbeam. you could just connect the low beam to the hids, and highbeams to your hella's. ps. to answer your pm to me, my ballasts are just zip tied upto another wire behind the headlight.
Old Feb 23, 2012 | 03:45 PM
norma jean's Avatar
norma jean
thanks, and wont that cut power to the low beams?
Old Feb 23, 2012 | 04:28 PM
reagor's Avatar
reagor
some creative diode/relay work can be done to fix this
tap both high/low beams with diode> trigger relay > HIDs
tap highbeam >relay2>hellas
i can explain in more detail if you so need
the lowbeams might blip during the switch
i dont know if this is ok for the HID ballasts
i think it can be smoothed out with a cap between the diodes and relay for the lowbeams
Old Feb 23, 2012 | 04:30 PM
norma jean's Avatar
norma jean
im a visual learner, can you make a diagram by any chance?
Old Feb 23, 2012 | 06:08 PM
reagor's Avatar
reagor
the arrows represent the diode direction
someone else can chime in on correct sizes
as far as the capacitor to filter the blip idk the correct size needed but it would go in parallel connected to the diode output side/relay
too small and it wont work and too big it would take longer to turn off the relay when you turned off the headlights
also the top relay would also work for keeping your factory fogs on with your highbeams i think
also test it before installing im not responcible for turning your truck into a parts car
Old Feb 23, 2012 | 06:29 PM
norma jean's Avatar
norma jean
yup you have scared me away from this, much appreciated seriously, i think itll just be easier to have a switch on the dash, linked to the hella (soon to be hids)
Old Feb 23, 2012 | 06:56 PM
FrenicX's Avatar
FrenicX
haha, i thought that was kinda funny. no offense intended at all, but it was like this:
"can you draw me a picture?"
"AHH!~ run away!"
Old Feb 23, 2012 | 07:06 PM
reagor's Avatar
reagor
"AHH!~ run away!"
hahhahha
maybe i should have used mspaint, and added in scotch locks and crimp connectors
at least the circuit is archived now
Old Feb 23, 2012 | 07:21 PM
norma jean's Avatar
norma jean
"AHH!~ run away!"
haha its just what i needed, at first only the diagram came up and im like this isnt too hard and then i went to quote it and then i saw all the explaination, and my thought was my truck blowing up, i just saw it as a wiring nightmare, my brother could have helped me do it, but i despise him. and then i just thought of the switch being the safer option
