Fender Flares
Old Feb 28, 2012 | 06:07 PM
Alfons's Avatar
Alfons
Default Fender Flares
This spring I'm planning on adding larger wheels which will also be wider than the originals. To compensate for the width I'll be getting a set of rims with a different offset to prevent the rubber from rubbing inside and will be lifting the vehicle with 2" leveling spacers & a 3" body lift to give me the clearance for the tire diameter. What I'm looking for is some suggestions/advise on after market fender flares (probably about 1" or so extension) that would install easily, not get in the way of wide 31 - 32" tires and provide the "rooster tail" coverage - we can get tickets here for spraying water on the highway from rubber extended beyond the fender well.
Old Feb 28, 2012 | 06:26 PM
Reject's Avatar
Reject
There are only 2 Fender flares out for our trucks, OEM Flares, or Bushwhacker ones, as far as I know.
Old Feb 28, 2012 | 06:27 PM
Mopar9610's Avatar
Mopar9610
I am in the same boat and am leaning towards the Bushwacker "entend a fender" flares for my 2008 Dakota Crew Cab. They are the only fender flare offered by Bushwacker for the 2005-2011 Dakota. If you are looking for the rugged "bolt hole" look I would suggest trying a different company.
Old Feb 28, 2012 | 08:59 PM
EVguy's Avatar
EVguy
Originally Posted by Alfons
. What I'm looking for is some suggestions/advise on after market fender flares (probably about 1" or so extension) that would install easily, .
I have the BW flares and they went on easy and look great.
I also did some fender mods and steering stops to get my tires under the truck without a lift. https://dodgeforum.com/forum/members...ums-tires.html
I just installed a 3" body lift and have a 2" leveling kit on the way. Wish I had gone with bigger tires now.
Sort of like 2 footitis with boats.
BFN
Randy
Old Feb 28, 2012 | 11:49 PM
projektdirtfab's Avatar
projektdirtfab
if you want to clear up to 33" without rubbing and have total coverage...just get fiberglass fenders. just as easy to put on as those sticky tape flares
Old Feb 29, 2012 | 02:01 AM
FrenicX's Avatar
FrenicX
is that with your pulled bedsides?
looks awesome!
Old Feb 29, 2012 | 07:13 AM
Alfons's Avatar
Alfons
I like those fenders but since the same manufacturer doesn't offer a "bolt on" rear fender to complement the front, you either need to do the work on the rear yourself or have a weird looking truck. I had considered getting the front fenders but can't get very enthusiastic about the the work needed to either fabricate or "pull out" the rear fenders & then repaint the truck. I've been toying with the idea of making a fiberglass mold to make something of my own - I'm not sure I'll have the time to do that this spring before adding a body lift and larger wheels, so maybe I'll just settle for the Bushwacker flares - at least on an interim basis.
Old Feb 29, 2012 | 02:15 PM
projektdirtfab
looks awesome!
no thats way back when i first put the fenders on. once i get the front and rear bumpers done ill put up a good pic.
were working with Hannemann fiberglass on a set of bedsides but chances are theyll be custom made just for us so i dont know what his plans are for releasing them to the public. they arent hard to make. just hard to make look good.
but im going to take some measurements for the 05+ ram bedsides. might just custom fit those to my truck
Old Feb 29, 2012 | 05:47 PM
Mopar9610's Avatar
Mopar9610
Does anybody know if there is a company that offers a fender fare similar to the "cut out" flare by bushwacker? I know they only offer the "extend a fender" for our 2005-2011 dakotas and I do like it but I was going for a pure off-road look and would love the "Bolt-On" look. Thanks.
Old Mar 1, 2012 | 12:37 AM
4XANDY's Avatar
4XANDY
I cant find fender flares for Ext cab dakotas, can any one help? why only quad cab?
