Couldn't crack 20 MPG
Old 04-02-2012, 10:08 PM
DakotaAgain?'s Avatar
DakotaAgain?
DakotaAgain? is offline
Originally Posted by RIFF-RAFF
recently drove from Toronto Ontario to Sarasota Florida (1400 miles each way) and averaged 19.1 mpg. That's through the mountains along I-77. Had about a 600lb load and stopped only once in West Virginia for fuel.
On a 1400 mile trip you only fueled once? That comes to 41 mpg.
Old 04-03-2012, 12:43 AM
durapu's Avatar
durapu
durapu is offline
I was going to ask what they were driving .. the other option is a 35+ gal tank
Old 04-03-2012, 12:52 AM
DakotaAgain?
Is there such a thing?
Old 04-03-2012, 04:51 AM
RIFF-RAFF's Avatar
RIFF-RAFF
RIFF-RAFF is offline
sorry fellas....I run a 33 gallon auxiliary fuel tank. I get close to 1000 miles per fill up.
Old 04-03-2012, 08:08 AM
Barkleyfan's Avatar
Barkleyfan
Barkleyfan is offline
I drove from northern VA to Philly today on I-95 doing 70-75mph. I just could not crack 20mpg. Got very close, like 19.8. How am I doing?
That's actually pretty good. I average 22mpg mostly highway. But that's at 55-65 mph, with 3.55's. Drop speed, you should jump up well above 20.
Old 04-03-2012, 08:45 AM
DakotaAgain?
30 mpg? Never heard of a Dak doing that.Where did you find the place to put it?
Old 04-03-2012, 10:39 AM
jkeaton is offline
Dodge Forum Administrator
I think he means 1000 miles between fillups using the 33 gallon aux, plus the standard tank (22 gal?)...around 20 MPG..
Old 04-03-2012, 11:33 AM
rodslinger's Avatar
rodslinger
rodslinger is offline
Default Can do it but it takes work....
My Dak has been from Atlanta to Miami and back on three trips. I can get between 19mpg and 21.9mpg highway depending on how I drive. (Quad cab, 2wd, 4.7, 3.92 gear)
If I just park the cruise control somewhere around 75mph I will get between 19.2 and 19.6 (gallons into miles driven).
If I park the cruise at 70mph it will get between 19.6 and 20.3 (gallons into miles)
If I keep it between 65mph and 70mph, no cruise and trail a rig part of the trip it'll get 21+ pretty consistently. Made a effort to maximize mileage on a leg from Orlando to Miami once and was able to squeeze 22.6 out of it. (Tires at 38psi, 65 -68mph, drafting a rig sometimes, etc)
This truck is hard to beat EPA estimates. I can get 35mpg out of my Sentra Spec-V pretty easily on highway runs when it is only rated at 28. Same for my wifes Mazda5. Can get 33 out of it on the interstate. Getting 20 out of the Dakota is a struggle sometimes.
Old 04-03-2012, 12:17 PM
RIFF-RAFF's Avatar
RIFF-RAFF
Not quite. I've gotten a best 19.1 mpg on a 1400 mile trip through the mountains. My auxiliary tank is 33 gallons on top of the factory 22 gallon tank. I've never run my main tank below 1/3 on any long distance drive.
Old 04-03-2012, 05:47 PM
Sunsetrider's Avatar
Sunsetrider
Sunsetrider is offline
I haven't been able to get even close to those numbers (even on the crazy computer readout on the overhead) even driving the equivalent of 55 mph . . . I am running 87 gas 87 tune. Wonder if 91 with perf tune will be more efficient?
I hate seeing the big numbers some of you are posting!
Quick Reply: Couldn't crack 20 MPG
