U guys never mentioned this size...
Old Nov 19, 2012 | 06:43 PM
DaKoCuN's Avatar
DaKoCuN
Question Getting new tires!
I'm finally getting the new tires this weekend!
I could not get the 2" leveling kit so my options are:
265/65R17 (same as stock size)
245/70R17 (same as my spare tire)
285/60R17 (like the wider look, not sure if it will fit)
265/70R17 (forget it, it will rub)
Any suggestions?
I'm in the market 4 new tires, after 65k KM I'm looking to get a new full set of tires.
Factory set up: 265/65R17
I'd been reading a lot in the Forum and I didn't found anyone mentioning the 285/60R17
Seems like a 265/70R17 is a very popular size!
Since I'm buying the 4 tires, what's the right way?
My tire shop offers:
265/65R17 (kindda costly)
265/70R17 (not bad $)
285/60R17 (very very good deal $)
FYI 2009 Dakota 4X2 stock
TY 4 u answers!
Old Nov 19, 2012 | 07:12 PM
Alfons's Avatar
Alfons
I use the 285/70R-17 size tires, I had the Nitto Terra Grappler on for the summer and just put on the Yokohoma Geolander. With a leveling kit and a lift, this size will rub just a bit on the frame as you do a full turn - the 60 series of this tire size would be quite a bit worse and would also be a lot harder on your steering & front suspension components.
Old Nov 19, 2012 | 07:50 PM
DaKoCuN's Avatar
DaKoCuN
The leveling kit is not 4 sale in Cancun so I'm keeping the truck stock until I can go to the US and get it, but the new set of tires is a must have in the next 2 weeks, that's why I'm asking wich way should I go...
Old Nov 19, 2012 | 08:15 PM
dakotaff's Avatar
dakotaff
Stock size, go with the 265/65/17. If you can find 285/60/17, (which only a few options are available), you could go with that size. But, I only see a couple of options in that size. If you have stock OEM steel wheels, it's not that good of an option. You'll need an 8" wheel, at a minimum, for that tire size, the steel wheels are 7" wide. On the Stock OEM alloy wheels, which are 8" wide, the 285/70/16 can work fine. A 265/65/17 is a much more common sized tire. I don't really see 286/60/17 being cheaper than a 265/65/17, but maybe it's cheaper in Cancun.
Old Nov 20, 2012 | 10:54 AM
DodgeCACares's Avatar
DodgeCACares
TY 4 u answers!
DaKoCuN,
I would have to encourage you to go with the factory set up, as those size tires were tested and have a confirmed compatibility with the factory build of your vehicle. Please note that non-dodge modifications do not by themselves void the warranty, but they are not covered by your warranty.
Old Nov 20, 2012 | 05:24 PM
DaKoCuN's Avatar
DaKoCuN
265/65R17 Wrangler Goodyear (made in China)
265/70R17 Cooper Tires (made in the US)
285/60R17 Hankook (made in Japan)
I believe my SLT came with OEM alloy wheels
Old Nov 20, 2012 | 05:27 PM
DaKoCuN's Avatar
DaKoCuN
So what I read is:
265/65R17 zero problems
285/60R17 zero problems
265/70R17 might rub
Am I right?
TY all guys 4 u answers&advices
Old Nov 20, 2012 | 05:35 PM
DaKoCuN's Avatar
DaKoCuN
Actually I got the quote $ from a tire dealer in Corozal, Belize (400KM away from here), it's like a FREE ZONE border area with no taxes, that's probably the reason of the cheaper tire.
I know 4 sure Cancun ain't cheaper at all!
And I'm going back to Belize in the early December 4 a business trip so I wanna take the opportunity to get the new set of tires (just waiting to make the size decision) I know I wanna go bigger but keeping the suspension stock.
Old Nov 20, 2012 | 05:38 PM
DaKoCuN's Avatar
DaKoCuN
Originally Posted by DodgeCACares
DaKoCuN,
I know TY but warranty works different down here... I ain't got no more warranty since the truck is a 2009 (only got 2 years of full warranty with the local dealer)
Old Nov 20, 2012 | 08:24 PM
dakotaff's Avatar
dakotaff
265/65R17 zero problems --> Correct
285/60R17 zero problems --> Should be correct, but it is a little smaller tire than 265/65/17, and nobody has tested that size yet.
265/70R17 might rub --> They will most likely rub.
If I was in your situation, I'd stick with the 265/65/17. But definitely let us know whatever tire that you end up buying.
