Rear Wheel Dakota MPG - 4.7 6 Speed vs 3.7 6 Speed
Hello all,
So I'm undecided as to which one I should buy:
2006 4.7 RWD Dakota 6-Speed
or
2008 3.7 RWD Dakota 6-Speed
I know both of them sit around the 19mpg on the highway mark - my drive to work is ALL highway and I'm just curious, can some current owners of v6 and v8 2 wheel drive Dakotas chime in on their mpg numbers they see?
I'm swaying towards the v8, but if the 6 is going get me consistently better mpg, I may go that route...
or
I can't speak for the 6 Speeds as mine is the 5 speed auto, but one of the reasons I chose the v8 over the v6 was because the mileage was practically the same between the two and for the little difference, I decide the v8 would give me more options for hp, torque, towing, resale, aftermarket, etc. Also note I owned a 3.9 prior to this so I kind of understood the even less attention it received as compared to the others
Hello all,
or
or
Mad,
If you want a build sheet on either or both of these PM me the vins and I'll send them out. I will also check for recalls and warranty restrictions.
there's no way around it, The factory front end components (bushings and tie rods, ball joints) are not built to last.
Get the v8, Its just cooler.
Trending Topics
