HELP! Tranny downshifting HARD....
Old Jan 24, 2013 | 06:14 PM
1sikeuro's Avatar
1sikeuro
Default HELP! Tranny downshifting HARD....
TODAY outta the blue my truck started shifting really weird. hesitation when it downshifts and then all of a sudden BAM it will down shift. but not in the correct gear. ive never seen anything like it. it shifts fine going up thru the gears, but any time it starts to lug and i give it some gas it will struggle to find the correct gear. On my way home the check engine light came on so its getting serious. im worried it will become mechanical if its not addressed asap. by the way i am running a superchips perfromance tune so i wonder if thats to blame. guys, any ideas on how to find out the issue or does any one have an idea whats going on? its my daily driver and vital that i am still getting to work..
Old Jan 24, 2013 | 06:43 PM
erau's Avatar
erau
First, have it scanned to see what code it's throwing.
Old Jan 25, 2013 | 12:28 AM
Tygarys's Avatar
Tygarys
Your superchips tuner should be able to read the code for you, that will at least give you an idea of what might be going on.
Old Jan 25, 2013 | 08:44 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
How many miles and has it ever had a trans. fluid change?
Old Jan 25, 2013 | 05:45 PM
1sikeuro's Avatar
1sikeuro
it has 165000 and ya i changed it as well as flushed the coolant at about 150ish. i take care of this truck like its my baby (it is) and as of now the fluid looks great and the level is perfect. today the check engine light went off.... but still kinda doing the hesitating downshift although not as bad. im lost. maybe a solenoid pack???
Old Jan 25, 2013 | 05:48 PM
1sikeuro's Avatar
1sikeuro
the tuner was stolen shortly after i bought it outta my truck by some dirtbag. so i maybe really screwed in order to reprogram it. other than taking it to dodge know of any way to set it all to default? they will charge 120 to do it....
Old Jan 25, 2013 | 06:33 PM
You still need to know what code it threw. Even though the light went out, it is stored, so go to autozone and get it scanned for free.
Old Jan 26, 2013 | 11:45 PM
Bajabob's Avatar
Bajabob
My 2006 4.7 Dakota QC just did the same thing to me today when I was a long hill. The check engine light came on so I hooked up my SC and it showed Code P0068 (manifold pressure/throttle position correlation). 1sikeuro, did you get the info on the code on your truck and is the same as mine. Could the throttle body be dirty and is it easy to clean?
Old Jan 27, 2013 | 06:43 AM
1sikeuro's Avatar
1sikeuro
i have not checked it yet. my buddy couldnt squeeze it in untill tomorrow. i have been waiting for him. i will be sure to let you know what it comes back with.
Old Jan 28, 2013 | 11:55 AM
Bajabob's Avatar
Bajabob
I took off my throttle body (very easy) and cleaned it with carb cleaner and a lint free rag. It was pretty dirty with carbon build up. It is now running smooth. I haven't tried it on a steep grade yet but drove it around the same area that I was having trouble on sunday morning when it popped a code. Hopefully this may help you out. Keeping my fingers crossed that I solved my problem.
