Steering Wheel Squeaking?
Hey guys its been a while, so as the title says i noticed for a while my steering wheel squeaks a bit whenever i turn at low speeds usually. I was just wondering if this is common or if i need to fix something. I sounds like its coming from the part that attaches the wheel to the dash column(or whatever its called). I dont know much of steering wheels and dont want to set off the air bag. Any input would be nice, thanks
I had the Same issue...I could have sworn it was from the steering wheel, it ended up being the bolt under the dash where the 2 shafts connect. Tightened it down and sqweek was gone.
I would try that first.
Mine had been squeaking for several years and all I'd heard was that the only way to fix it was to replace the steering column. I recently found the actual Dodge TSB. It says to first loosen the two bolts that holds the steering column flange to the floor, then turn the steering wheel back-and-forth several times to center it before tightening the flange back down. If that doesn't fix it, then replace the column..., Hallelujah, it worked!
The clunking sound and looseness comes from the coupling between the upper/lower parts of the column. It's a crappy design with what looks like a round female half trying to clamp around a square male half. I tightened mine down several times but it would always come back. I finally got tired of it and drilled a hole through the joint and bolted it.
Yeah mine did that as well. I had Dodge fix it for around $200. They said it was a TSB which I assume was the same djsilver's. Since I wasn't sure of the difficultly I let them do it so I didn't get a face full of airbag.
FYI, these trucks have had a gremlin in the steering. There have been several reports of a bolt coming loose in the steering linkages from the steering wheel and people have lost steering completely.
http://www.carproblemzoo.com/dodge/d...g-problems.php
The info I found was in a Dodge publication in the waiting room at the local dealership. They were looking into why my back-up lights don't work (they haven't figured it out yet...,) The advisory only addressed the squeaking and the clunking from the loose joint. Their instructions for the loose joint is to replace the pinch bolt and re-tighten the joint. It was my decision to drill and bolt it.
Apparently, the 3rd Gen Dakota has a high failure rate for front-end components, including upper/lower ball joints, steering column universal joints, steering racks, steering tie-rod ends and shock absorbers. at 116k, I've replaced my shocks and my sway-bar end links but everything else is still tight. Mine is 2WD and I don't go off-roading but I do use it and tow with it, so I guess I'm just lucky so far. (?)
great info guys, i've been busy all week with school. Will definitely get to the bottom of this very soon!
Trending Topics
