Programming Only Remote Fob (no sentry)
I'm the proud owner of an 05 SLT QC, and I'm having remote fob issues...here are the facts that got me to where I am.
1. When purchased, the truck came with one black fob. I am positive that there is no sentry system since I've been able to use regular metal spare keys for quite some time.
2. Way back, I noticed the remote being spotty at best and then it died. So I changed the battery but that didn't seem to work...but I did no re-programming because I didn't know anything about it.
3. Someone tried to steal my truck, messed up the steering column and cylinder lock. I replaced the steering column with one from an '06 Raider and the new ignition system also has not sentry system.
4. For a while, I was rolling on 2 keys, one for the door (since remote doesn't work), and one for ignition. I just recently had the ignition cylinder lock re-keyed back to the original key.
5. How do I program the one and only original remote to my new set-up. How can I tell if the remote itself is bad since I was having issues long before the steering column replacement.
I'm in the process of prepping this truck for sale so I'd like to figure this out.
Thanks!
Thanks!
To program a remote, You require 2 OEM Factory (I think, or just 2 Working FOBS alreayd programed) to the truck. If you only have one, Dealer has to program it/others.
I dont have the FOB's I just have a Sentry System (Chipped Keys) the steps are different between them for programing I think.
Do a Search I think the steps for Both ways are on here. Somewhere.
So then what I'm reading, with just one Fob, my only option is for the dealer to program? Could they do this with one, or would I first need to purchase a second.
Now for some opinions...it it worth me spending money on this (of course depending on how much), or just sell as is where a key would be required for entry.
My 05 Quad cab came with only one fob that was messed up worked some of the times took it apart and found the metal battery clamp had broken off . After messing with it first with superglue Worked for awhile then stopped working.Then broke out the fine tip soldering iron and reattached it now works fine . ordered new one from local locksmith had them program it also cost was $190.00 programed and this was a original Dodge key not aftermarket. So find a good locksmith and they can for sure take care of programing new key fob. Sorry about long reply and good luck
Trending Topics
Thanks for all the helpful replies.
My biggest issue (and I admit I don't know much about this subject) is that I now have the original fob, but a steering column from a Raider which presumably has a different "code" than what was original the the Dakota.
Without knowing the VIN of the Raider, could fobs be programmed because I wouldn't be able to order one specific to that receiver.
Make sense?
Make sense?
