curb weight for coilovers
Old Mar 26, 2014 | 02:59 PM
rookie's Avatar
rookie
Default curb weight for coilovers
had this in my other thread; reposting:
so I am figuring my curb weight at the front corners for when it comes time to plug in the #s on the spring rate calculator. my truck is pretty base (st) except for the 4.7 and 4x4. the mopar specs I have seen say 1926 for the front end so / by 2 and subtract unsprung for each corner. anyone wanna guess the weight of the factory spec steel wheel, 245 tire, control arms, hub, knuckle, rotor, brake, misc and half of the shock, tie rod assembly, and cv? 150lbs? am I missing anything?
Old Mar 26, 2014 | 03:43 PM
projektdirtfab's Avatar
projektdirtfab
That's about how you do it if you dont have access to corner scales. I can weigh the spindle and hub when I get home. Going to have to estimate on tire and rim weight. Remember its just a street prerunner not a full race truck so plus or minus 50 lbs wont have an affect.
Old Mar 26, 2014 | 08:43 PM
rookie's Avatar
rookie
Yeah, I'll be like: "kids, take the bus, your effin up my pre-load!"
Pre-runner sounds so 2wd. I'll have to put the stupid 4x4 sticker back on. (no offense to anyone that has them; I de-badged the whole thing.)
Old Mar 26, 2014 | 10:57 PM
projektdirtfab
Bros call anything a prerunner lol. A "prerunner" is anything used to "pre-run" a course. A quad could technically be a prerunner.
Old Mar 27, 2014 | 10:01 AM
rookie's Avatar
rookie
that was my assumption, because of the terminology.
Most applications similar to mine are going with 8" COs, albeit 2.5" (see the caddy II total chaos kit). I am thinking that I will go with 10" 2.0s cause I would rather have the xtra just in case. Is this faulty logic? I think 2.0s seem adequate, and everything indicates that I will have room for 10"ers. And for a few bucks more why not? I am more worried about the diameter as far as fitting them goes.
Old Mar 27, 2014 | 02:04 PM
projektdirtfab
Yea its good to have a little extra. Just as long as your bumped and strapped. Thats one obstical I haven't figured out is fitting 2.5s
2.0s are plenty for daily driving weekend smashing but it's always good to have 2.5s if they fit. That way they don't work as hard.
Old Mar 27, 2014 | 03:08 PM
rookie's Avatar
rookie
My cvs are keeping me from doing it. 2.0s will be easier to work with up top too if I incorporate the original spring bucket in my upper CO mount (might just let the COs go through the top). Cant see what would get in the way of 2.5s if your 2wd. Strap is no prob; where's your bump gonna b?
Old Mar 27, 2014 | 03:53 PM
projektdirtfab
There's going to be a bump can welded to the frame and it will bump on the lower CA. given my tires clear at full lock.
Old Mar 27, 2014 | 10:18 PM
rookie's Avatar
rookie
Clear the fenders? I will be needing those at some point, but I may just alter the stockers if yours don't clear.
Old Mar 27, 2014 | 11:10 PM
projektdirtfab
No if the tires clear a bump can welded to the frame. Probably where the sway bar used to be so it should clear....
