Install Fuel Check Valve
Old May 12, 2019 | 11:57 AM
Secshunate's Avatar
Secshunate
Default Install Fuel Check Valve
Hi everyone,
i’ve got a failed return valve on the fuel pump assembly of my 2006 Dakota CC 4.7 4x4.
its been causing hard starting for a while and the dealer has diagnosed it but quoting me huge $$
instead of replacing the whole fuel pump assembly, I’m hoping to install a simple check valve but I’m not sure if there are any areas where the fuel line is rubber hose where I can splice this in.
Any advice / suggestions?
Old May 12, 2019 | 02:18 PM
primem's Avatar
primem
cycle the key 4 x and let the fp run for a few seconds each time...then start it. this will prime the fuel system and it will start normally....and you spend nothing.
they don't use rubber anymore...its either plastic or steel. both can be sectioned in with compression unions designed for each material.
Old May 12, 2019 | 02:47 PM
Secshunate's Avatar
Secshunate
Thanks, yes I’ve been doing the pump cycling for a year but want to sell truck soon. I was hoping for a way to get a check valve into the line somewhere. This is the second pump with a failed return valve and I don’t want to throw another one in.
can anyone tell me what the fittings are called so maybe I can try to buy a short rubber section with the right fittings to splice in?
Old May 12, 2019 | 03:37 PM
Secshunate's Avatar
Secshunate
I’m reading now that it is possible to cut the nylon pipe and heat the ends with boiling water to accept barbed fittings and clamps. So I guess that’s what I’ll be doing.
Old May 12, 2019 | 06:19 PM
Secshunate's Avatar
Secshunate
Looks like problem solved! There is a section of aluminum line along the frame rail which comes off with quick connectors to a 34” section with some bends. Pipe cutter a piece out, flare the ends and used some fuel hose to splice in the valve. Now she holds pressure and fires up faster than ever.
Old May 12, 2019 | 09:06 PM
dakotaff's Avatar
dakotaff
Looks like a good band aid remedy, I guess the next owner can deal with the actual problem.
Old May 12, 2019 | 09:08 PM
Secshunate's Avatar
Secshunate
Funny, I thought the actual problem was pressurized fuel leaking back to the tank. Do you work as a mechanic at a dealership by chance?
Old May 12, 2019 | 09:13 PM
dakotaff's Avatar
dakotaff
No, so I can't offer advice on a repair suggestion. But I would not want to be the surprised next owner to find that installed, but that's just me.
Old May 12, 2019 | 10:40 PM
Secshunate's Avatar
Secshunate
I can understand that apprehension, but basically all I’ve done is add another check valve downstream from the broken one. See, the Chrysler engineers, being so clever, decided to make a fuel pump “assembly” which combines the pump, filter, float, check valve all in one, but their check valve is obviously ****, because two have failed for me. Why play their game and replace all the expensive parts, that still work fine, just because the cheapest component fails?
Old May 13, 2019 | 12:04 AM
primem's Avatar
primem
he is right, your fix is a band aid. there is a reason they don't use hose clamps on fuel or cooling systems....they loosen and leak. Not just fca...every auto manufacturer...they don't want to get sued.
