My truck keeps blowing coil#1
Old Nov 27, 2020 | 02:51 PM
  #31
My guess would be very close to zero.....
Old Nov 27, 2020 | 05:56 PM
  #32
David Kalinowski's Avatar
David Kalinowski
Lol whatever it is, I've been driving all day today getting up to 75 mph (after putting in a new coil) and it's running like a champ. So after months of not working and frustration, it was a damn wire.
Old Nov 27, 2020 | 06:54 PM
  #33
pilotsmack's Avatar
pilotsmack
Sounds about right. Hopefully it stays fixed! So just a chunk of wire at the coil connector end?
Old Nov 27, 2020 | 09:21 PM
  #34
David Kalinowski
I snipped it about 4 inches from the ECU and about 4 inches from the coil and just wired (piggy backed) a new thicker gauge wire (not much thicker, may one-two gauges up) and routed it up and over the engine back by the fire wall. (zip tied to some little hose that was already zip tied back there, I'm thinking it was the washer fluid hose.)
Old Nov 28, 2020 | 06:44 AM
  #35
erau's Avatar
erau
Originally Posted by David Kalinowski
Okay so I got the test light, it just flickered really fast on every coil I tested, so I then checked continuity and it was there, so as a last ditch effort I snipped the drive wire on from the ecm and from the plug, spliced in a new wire, moved the coil from cylnder 4 over to 1 and the only coffee being now is for cylinder 4 because there is no coil there. So after all this time it appears to have simply been a bad wire. I have to get a new coil tomorrow probably order it tonight so more like Monday or Tuesday, but I'll update more after that.
Sweet!!
Old Nov 29, 2020 | 11:12 AM
  #36
Jaded's Avatar
Jaded
Thats one down, hope the other guy gets his coil prob fixed too. You still going to sell it?
Old Nov 29, 2020 | 01:57 PM
  #37
David Kalinowski
I'm not sure, if I do probably after people start getting their tax returns. I'm fairly certain there is an exhaust leak some where now. I think it's at the manifold.
Old Nov 29, 2020 | 07:36 PM
  #38
erau's Avatar
erau
Broken manifold studs, especially toward the rear of the engine, seem to be a periodic topic here.
Old Dec 1, 2020 | 08:32 AM
  #39
northgator8's Avatar
northgator8
And I can't find exhaust manifold studs anywhere . . .
Old Dec 1, 2020 | 09:05 AM
  #40
David Kalinowski
dorman 03218 and fel-pro ES75109 is what rock auto is showing. It looks like it sold as "exhaust manifold hardware" :rolleyes
https://www.rockauto.com/en/catalog/...hardware,15114
Amazon Amazon
