06 dakota quad : cold tranny?
Old Mar 31, 2006 | 04:31 PM
  #21
budking's Avatar
budking
Default RE: 06 dakota quad : cold tranny?
Thanks for the advice. When I left for work today it was about 65 degrees outside AND I let it warm up. Still got a high RPM rev with no "go". gradually dropped into first. Not good.
Old Mar 31, 2006 | 06:27 PM
  #22
sawfish's Avatar
sawfish
I have the same situation with my 2005 QC 4.7L AWD, but I think you guys are stressing out over nothing. I had the same symptom to a degree with my 1993 3/4 ton Suburban 4WD. It just takes a little bit to get the fluids warm and flowing. The Suburban has over 150K on it, and is still going strong. I do not perceive this as a problem, but something more akin to letting your geartrain warm up before putting it under a load as in limited slip differentials.
Old Oct 8, 2006 | 09:46 PM
  #23
fan8157's Avatar
fan8157
this is normal,its done to warm up tranny fluid.these trucks have done this for years.nothing to worry about
Old Oct 8, 2006 | 11:03 PM
  #24
superdak05's Avatar
superdak05
no problems here, get in the morning, start truck for a few seconds and smoke the tires as i leave the driveway like i do every morning.
