clutch fans?
Old Sep 29, 2006 | 03:20 PM
trucky's Avatar
trucky
Default clutch fans?
hey everyone...whats the big deal with clutch fans? i see in a lot of signatures where peeple are listing their mods....they say they have removed that... call me a noob but i dont know what that does to help? and if i am the copycat i know i am...i'll do it too. but should i leave it on for winter? thanx for answering my retard questions
Old Sep 29, 2006 | 05:25 PM
QCDAKblue's Avatar
QCDAKblue
Default RE: clutch fans?
The fan draws HP from the engine. However I would not reccommend removing it. Vehicles can run hot in the winter as well. I believe you can safely remove the fan if you add an electric fan with a sensor that will turn it on and off. I would suggest you leave it alone, the Dak will never be a hot rod truck. I do have to agree it is a noisy fan tho when you start up.
Old Sep 29, 2006 | 09:01 PM
trucky's Avatar
trucky
what if i swap it out with a flexalite? how do i know which one to get though...i've looked at them a long time and dont know where to start
Old Sep 30, 2006 | 09:58 PM
Mean Green's Avatar
Mean Green
A lot of people do this because of power issues plus more mpg's and less noise. The 1st gen Durangos and 2nd gen Dak's can have a viper fan swapped right in with some wiring and some other minor mods. I am going to do it myself since my Durangos clutch fan is going out anyway, might as well get some power back for an extra 150-200 bucks...
Old Oct 1, 2006 | 02:30 AM
Frenchy's Avatar
Frenchy
How would someone find and remove a clutch fan on their truck?
Any one got a good set of pictures, or a walk through?
Old Oct 1, 2006 | 02:40 AM
trucky's Avatar
trucky
its fairly simple, i began the work myself...removing the fan guard with the stupid plastic screws...wrench out a cupple nuts... then reach down and undo the 4 fan bolts...this is complicated, and i stripped the last one, and now im stuck...cuz i cant get it off.
Old Oct 1, 2006 | 02:44 AM
Frenchy's Avatar
Frenchy
Got pics?
*Got Milk?*
hehe
Old Oct 1, 2006 | 07:12 AM
trucky's Avatar
trucky
itd just be a picture of the same thing ud look at when u open the hood : o ).
Old Oct 1, 2006 | 08:22 AM
Frenchy's Avatar
Frenchy
So it's that big yellow plastic fan then hey?
Old Oct 1, 2006 | 09:32 AM
sdsdsd's Avatar
sdsdsd
Removing your clutch fan is looking for trouble. This is designed to turn the fan when it is needed. the fan turns of and free wheels at highway speeds. Hiway is when you don't need extra cooling from your fan.
