Oil Level via Dipstick (5.7 Hemi)
So, I have the Citadel 5.7 Hemi AWD and I am on my 2nd oil change. For the first oil change I used Mobil1 5W20 with the K&N 2010 oil filter. My second oil change i used same oil (Mobil1) 5W20 with the Mobil1 M1-210 filter. All oil changes have been performed by Dodge dealer. Each time there are (7) quarts added as per manual added.
My question/concern is that whenever I check my oil level via the dipstick (usually check in the morning after car has been sitting all night) on level ground of course, it looks like the oil just makes it up to the add line. I thought it was just me, but now after the second oil change it's the same situation. The oil pressure is fine (about 27-30 at idle and 47-50 during drive), however, how does one know when oil needs to be added? At one point, I thought it was the anti-drain back valve not draining the oil back into the reservoir, but am not even sure if that plays the part here.
Curious of your thoughts?
I did mine by the dipstick, to the full line (same engine/tow package).
I used two five quart bottles so wasn't able to notice how many quarts used. This is the first I've heard of this issue.
If you can't use the dipstick to measure your oil level, what else is there?
Just fill it to the full line.
