Auto leveling xenon headlights - adjustments?
When I start the car, the auto leveling appears to work as the lights rise and lower when the lights come on.
When driving, the xenon has a sharp cutoff at it's horizon and I can see that the driver's light is a little lower.
Dealer says this is how they are calibrated so as to not blind opposing traffic. Makese sense.
Is that the correct alignment?
I have read the the left is lower as to not blind oncoming traffic and the right is a bit higher to illuminate traffic signs on the right side of the road. This is the way mine look when I start it up and it shines on the garage door.
When you next think about it, get closer to the door at night. You will notice that both headlights have a lightning bolt upper cutoff. The left side is lower to not dazzle oncoming traffic. As far as I know, all modern factory HID headlights have that same cutoff design.
Look at this photo posted in the LED fog light thread. Notice the left beam is lower; it is by design, no worries.
Photo Credit to kingofwylietx
Trending Topics
Because of the projectors (the glass ball covering the lamps) the lights are really even and then cut off completely. They should be aimed perfectly it is just a lot easier to notice the differences with three protector lenses.
