3rd Gen Durango 2011+ models
adding oem entertainment system
Old Mar 18, 2013 | 07:57 PM
  #61
pedsemdoc's Avatar
pedsemdoc
Thumbs up
Franco, I like the radar mount on the mirror. I want to do the same thing with my detector. I also think hardwiring it will give it a cleaner look. I think you can run the power to the back of the mirror--I just don't which connector on the harness in the mirror you need to hook it into. I guess you could use a meter and check to see which lead has power/which is ground, when the car is on.
Otherwise nice install!
Old Mar 18, 2013 | 09:41 PM
  #62
franco90's Avatar
franco90
I have to order the hard wiring kit. My original plan is to make it a clean install
Old Apr 4, 2013 | 09:06 AM
  #63
franco90's Avatar
franco90
OK OK here is the final product
Kenwood 7 in Flipdown and it does not block the rear view mirror
Old Sep 2, 2013 | 09:08 PM
  #64
brental1's Avatar
brental1
I found one on eBay for $35 (don't think the guy knew what he had). The most expensive component was the mounting bracket. Think it was about $150 from the dealer. The hardest thing for me was to find a connector to build the harness. I have a complete IP harness from the junk yard, and not one of the connectors from it would work. Found one in an audio shop in a guy's junk drawer. After that, it was plug and play. My headliner was not quite the correct contour; but make it work with some cutting and finessing.
Old Oct 1, 2013 | 07:45 PM
  #65
franco90's Avatar
franco90
here is my new set up
Old Oct 23, 2013 | 08:42 AM
  #66
franco90's Avatar
franco90
thi thread Just DIED
Old Oct 23, 2013 | 12:41 PM
  #67
CMil527's Avatar
CMil527
looks good franco..
Old Oct 23, 2013 | 01:28 PM
  #68
V for Victory's Avatar
V for Victory
That's awesome Franco, now everyone can watch movies including the driver in the car behind you! LOL
Old Oct 24, 2013 | 06:44 AM
  #69
Blue659's Avatar
Blue659
I was going to post my latest mod, two alpine amps, 4 new door speakers and new 8" kicker sub but instead I took everything out yesterday. It sounded really good for a couple of months. It looks like I am jumping into a 2014 Hemi D soon. I will post photos and a review of the new radio. I am also curious to see if dodge change the sub in the 2014.
By the way guys, I posted the 2012 alpine system wiring code on another page... I also made a diagram using MS Paint.
Old Oct 24, 2013 | 07:36 AM
  #70
FSTDANGO3's Avatar
FSTDANGO3
SAme sub in 14's
