I really want DRLs!
You can go to the dealer and they can enable the DRL's from what I've learned. When I have some time I'll look for a power feed to wire them up on ignition on. I'll try to find out if I can use the factory fog push button to turn them on and off but it might take some time as I am busy the next week.
I have drl's from the dealer, they used a starscan device to enable. high beams are used just at a lower wattage, not low beams.
i love the look of just my fogs on I drive that way all the time
I would suggest opening the headlights up and installin DRLed's, 1 strip inside each headlight. Would look sick and theres a PERFECT spot in there almost looks like by design for a strip of LED:
its project 11 on my to do list, low priority cause im happy with DRFogs !
Trending Topics
I thought the same thing about putting the LED's in the headlight housing and then I saw the 2014s.... (figures)
Then I thought about mounting these:
here :
The measurements seem like they would mount perfectly under those vent cutout spots. I was hoping they would mount inside but they are a little longer than what I measured so under would work and follow the curve upward. Anyone good at photo-shopping to see what they might look like?
here :
