3rd Gen Durango 2011+ models
UConnect Problem 2011 Crew
Old Nov 11, 2013 | 10:07 AM
Big John49's Avatar
Big John49
Default UConnect Problem 2011 Crew
Recently started having issues when we first start our Crew in the morning with the UConnect system. The phone does not connect, or the radio doesn't work, or total failure. Anyone else having similar issues? Interesting that once re-started the system seems to be OK.
Old Nov 11, 2013 | 05:58 PM
Fullslp's Avatar
Fullslp
Might need a system update. Try starting the vehicle with your phone(s) OFF, let the system boot up then turn your phone On and see if it crashes. If it doesn't crash you prob just need an update. There may be a thread on
Here but I came across this info on a jeep site with the 430/730 nav systems having loading issues while simultaneously starting Uconnect with your phone.
Old Nov 12, 2013 | 08:44 AM
Big John49's Avatar
Big John49
Default UConnect Problems
I will try this and advise.
Old Nov 13, 2013 | 02:45 PM
DodgeCACares's Avatar
DodgeCACares
Big John49,
Keep us posted if this helps pin point your problem. If you do need additional assistance or have questions please PM me your VIN# and I'd be happy to help.
Old Nov 14, 2013 | 08:52 AM
Big John49's Avatar
Big John49
Angry Still Having Issues
Well the shut down of the phone and trying to get an update did not help. We have two cell phones connected. Would deleting one help?
Old Nov 14, 2013 | 06:48 PM
Fullslp's Avatar
Fullslp
So with the phones off the system booted up normally but when you turned the phones on (vehicle running) it crashed?
When you say you updated the system did you go to a dealer and have it updated?
I would remove both phones and then reconnect only one and see if that resolves it.
Old Nov 18, 2013 | 01:44 PM
xsdbs's Avatar
xsdbs
1) Can you give more information on your terms (The phone does not connect, or the radio doesn't work, or total failure.)
Do you mean that the radio itself doesn't work at times?
2) shutting the phone off & then back on doesn't reboot the phone. That's done either by removing the battery fir a few minutes then reinsert it, or in the case of an Iphone, you hold down the home & power buttons till the apple appears then release them. The phone will now reboot.
Old Nov 22, 2013 | 06:40 PM
Velez709's Avatar
Velez709
I too am having problems with the sound quality on my durango. It is a 2011 I just bought it so not sure of there has been an update. The sound quality is horrible it has like an extra hissing sound while streaming. Another question does the uconnect usb port play Pandora? Pandora freezes while trying to play music.
The phone I am using is an iPhone 5 with iOS7
Last edited by Velez709; Nov 22, 2013 at 06:43 PM. Reason: adding more information
Old Nov 23, 2013 | 07:49 AM
Big John49's Avatar
Big John49
I unpaired one of the two phones and the problem had resolved itself. I have since repaired the 2nd phone two days ago and so far so good. I will let you know if I encounter further issues.
Old Nov 23, 2013 | 07:38 PM
Fullslp's Avatar
Fullslp
Awesome, glad it worked out.
