Driving On the Full Size spare help
OK...I blew a tire...holiday weekend...will it hurt to put about 100 miles on the vehicle using the full size spare...trailering a 5000 pound boat too..
I am worried more about the AWD system and possibly causing a problem due to 3 tires being one diameter and the spare a different.
Please let me know your thoughts. I know there are a lot of you out there with the working knowledge of the transmission and transfer case.
Vehicle is a 2014 R/T AWD.
More likely, it's a "full size temporary spare" and not a "matched full size"
Full-size temporary spare tires and wheels match the vehicle's original tire dimensions, but typically feature lighter-weight construction and a shallower tread depth to reduce vehicle weight to improve fuel economy and make the spare easier to install. While most of today's vehicles are originally equipped with alloy wheels, full-size temporary spares are typically mounted on steel wheels and should be used only as spares.
That said, there's a reason that tow groups come with a full size spare. You'll be fine on it. Just be mindful of the shallower tread depth if you encounter water and take it easy as the tire isn't as heavy duty as the others.
Trending Topics
My full size spare is OEM 18" Goodyear that is a regular production tire. The difference of a few lbs of air pressure in a tire will make more diameter difference than wear. Keep you tires at 38lbs and you spare at 32 lbs and your tires could have 0/32" and they will still be a larger circumference.
