3rd Gen Durango 2011+ models
NAG1 Transmission trouble
Old 01-06-2015, 10:28 AM
gregaperkin's Avatar
gregaperkin
gregaperkin is offline
Unhappy NAG1 Transmission trouble
I'd really appreciate it if someone could help me understand if my transmission trouble is a known fault with a known fix, or something that needs more investigation. I love that vehicle, but the transmission is not spoiling the party. Here are the details... Many thanks in advance.
Dodge Durango 2012 3.6 Pentastar with NAG1 Transmission
TRANSMISSION PROBLEMS
There is a violent shunt when shifting under medium to hard acceleration. This applies to both kickdown and upshift. Mostly 3rd to 4th. Shunt is so hard it feels like the transmission will break, and the car physically lurches.
Also, usually resulting from the first problem, the car is occasionally stuck in a high gear and will not shift to first or second. This makes it difficult and slow to pull away after stopping in traffic. Also, the 'manual' gear selector will not work during this fault. The fault only resets after selecting reverse and then back to drive.
On one occasion, the transmission dropped out of gear at 100kph would not select another. During this time, with constant throttle input, the engine rpm varied between approximately 2000 and 4000rpm. I had to pull over to the side of the road. The fault only cleared after shutting off the engine and starting it again.
Old 01-06-2015, 07:13 PM
redalty's Avatar
redalty
redalty is offline
I'm not sure here but might want to call dealer and verify it's the NAG1. The Hemi Durango shares the 65RFE with the trucks.
Old 01-06-2015, 07:32 PM
Fullslp's Avatar
Fullslp
Fullslp is offline
The nag1 is extremely sensitive to fluid quality and level. The servo inside is computer controlled and will always try to correct an error in line pressure causing erratic behavior. Change your fluid and filter if you haven't already. Could really be a number of issues, from valve body, to servo to clutch packs. Find a good transmission shop. Not amco or trannys R' Us, lol
Old 01-06-2015, 10:04 PM
FSTDANGO3's Avatar
FSTDANGO3
FSTDANGO3 is offline
Dont google Tranny's R US either that will give you more trouble than your NAG1 could ever give you
I believe its a 654RFE as well
STEVE
Old 01-07-2015, 09:19 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Do you know if any fault codes were stored in the system? Have you contacted your servicing dealer to have the transmission inspected for the condition?
Old 01-07-2015, 10:24 AM
Fullslp's Avatar
Fullslp
Fullslp is offline
STEVE
Steve is both right and wrong. Right that you should not Google trannys r us.. Haha and wrong in that this is a W5A580 or Nag1. All 11-13 durangos with the 3.6 have this transmission as this engine doesn't have the torque to pull off the ridiculous 2-4 shift gap that the 54RFE AND 65RFE utilize. No worries I got you Stevo...,
Old 01-07-2015, 11:07 AM
FSTDANGO3's Avatar
FSTDANGO3
I wasnt paying attention to the V6 stuff...Thanks FullSLP even Durango Gods get tired once in a while J/K LOL
STEVE
Old 01-07-2015, 01:31 PM
Fullslp's Avatar
Fullslp
Fullslp is offline
Your probably just tired of of the cold and shoveling snow. I have no excuse as its 74 degrees here in Carlsbad Ca. Ah, what to do today. Hit the beach because I'm wearing shorts and flip flops?,,, sorry had to rub it in for you east coast er.. Pretty much everyone else in America guys.. OP KEEP US POSTED ON R&R.
Old 01-07-2015, 07:40 PM
FSTDANGO3's Avatar
FSTDANGO3
Probably its 8 degrees at my house right now...good news it 60 in my garage.
STEVE
Old 01-08-2015, 02:58 PM
Crew Member's Avatar
Crew Member
Crew Member is offline
Just curious how many miles you have. Over 60k and out of powertrain warranty coverage?
Quick Reply: NAG1 Transmission trouble
