2017-18 Adaptive Cruise control in Stop and Go traffic
First time poster, I am thinking about getting a 2017-18 Durango. I have a few questions about the ACC (adaptive cruise control) Does it work in stop and go? my commute is GARBAGE over an hour for 25 miles. I want to be able to push a button and basically just steer. How does it fair in stop and go for a half hour?
The original adaptive cruise could apply braking power, but would only slow you to 15 mph before deactivating with an alert tone.
The newer version with full stop will work to both slow and fully stop your vehicle in bumper to bumper traffic and will not deactivate.
When traffic moves, it will start moving. The problem with the ACC is the following distance presets (although proper) leave too much room and other cars have enough room to cut in.
roog
Coldsteel said: "The problem with the ACC is the following distance presets (although proper) leave too much room and other cars have enough room to cut in. "
That's the main reason I will never have ACC. I use cruise on the highways when I have options to change lanes, speed up, slow down etc. but to let the computer run everything goes against my control-freak personality, I guess.
The other issue that I have with it in heavy stop and go traffic (in my 2015) is that unlike a human driver, it's watching distance. You as a driver see brake lights cascading towards you from a few cars ahead and adjust your speed in advance. The adaptive system does not, and at times the stopping is bit abrupt. The major problem with this is that drivers behind you can be caught off guard by the system's behavior. I have concerns that it could get you rear ended.
That said it is still a great system. I use it daily in my commute but traffic is usually moving pretty quickly.
Trending Topics
