View Poll Results: What CAI do you have or recommend?
K & N
245
35.66%
Air Raid
77
11.21%
AEM
25
3.64%
Mopar
36
5.24%
Volant
59
8.59%
Afe
32
4.66%
True Flow
7
1.02%
S & B
15
2.18%
Ram Hammer
9
1.31%
home made
113
16.45%
ebay or other (specify in a post)
69
10.04%
Voters: 687. You may not vote on this poll
Old 08-05-2015, 09:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Cold air intakes
Old 09-22-2012, 09:30 AM
willdikem66's Avatar
willdikem66
willdikem66 is offline
Yeah because the Stock Box with a drop in K&N is just as good as any CAI. and the Box being closed adds to the colder air factor
  #322
Old 09-22-2012, 12:44 PM
08HEMI1500's Avatar
08HEMI1500
08HEMI1500 is offline
Yea I'm actually considering going back to that just because I'm too lazy to make a heat shroud for my intake now lol
  #323
Old 09-22-2012, 02:45 PM
looka's Avatar
looka
looka is offline
This is what I might do. I've looked at some of the home made CAI's that hook into the throttle body and they just look really junky to me. Some of the more expensive CAIs, like the volant, look nice, but I don't want to spend that much money. The Hemi resonator looks good so I'll probably just keep it stock and drop in a K&N.
  #324
Old 09-22-2012, 08:51 PM
willdikem66
Youll get about the same increase.
  #325
Old 09-22-2012, 10:35 PM
looka's Avatar
looka
looka is offline
I was working on my truck today. Along with replacing my front struts I decided to build a CAI. I spray painted it black, look, meh, ok. I also cut off my muffler and cats and threw on a cherry bomb extreme. It's loud a hell now, but I don't notice any extra horses or low end torque.
I'll probably bump my muffler down to a cherry bomb pro and put the hemi hat back on.
  #326
Old 09-23-2012, 09:08 PM
broggyr's Avatar
broggyr
broggyr is offline
I've been wondering about this. Well, I took your advice. I removed the huge hat from the 4.7 and ran a 3" PVC from the throttle body to the stock filter box which contains a K&N replacement.
  #327
Old 09-24-2012, 12:16 AM
looka's Avatar
looka
looka is offline
That's what I want to do, right there.
  #328
Old 09-24-2012, 12:41 AM
broggyr's Avatar
broggyr
broggyr is offline
It's super easy. 2-foot section of 3" PVC pipe, $5; 90• street elbow (flange on one end only, $3; two 3" couplers, $6/ea. Total cost $20 (I already had the K&N filter) and 15 minutes work.
  #329
Old 09-24-2012, 07:48 AM
DodgeBluto's Avatar
DodgeBluto
DodgeBluto is offline
Earlier in this post I ranted about most of the DIY intakes being worse than stock due to the multiple 90• bends. I still stand by that but as mentioned above I agree the stock air box and better panel filter is just as good as after market CAI and better that most DIY jobs.
The surface area of the panel filter is bigger than the surface area of "some" cones.
And I agree it is better for cold air. I was thinking of opening the side of the stock air box along the fender side. I think that might yield access to more air.
On my 5.9 the big issue seems to be that crappy caved in stock hat on the TB. I was thinking of using a hybrid of stock air box an a spectre TB hat that stands a little taller.
I like DIY mod experiments as long a they don't have a negative impact.
  #330
Old 09-24-2012, 09:57 AM
willdikem66
You arent going to notice a increase in anything wit your cats off, unless you have a custom tune.
You will constantly be running rich/or lean. period. Your Cats are plated with a ion that changes the chemical compound of the gas, this is why they have 2 different kinds of o2 sensors (Pre Cat/Post Cat).
And adding a muffler will not change the Hp/Trq output that much either unless you go from alot of restriction to none, which would be better for Hp/trq. I have Cats with no muffler, it by far has put more Torque down than anything else.
Quick Reply: Cold air intakes
