View Poll Results: What CAI do you have or recommend?
K & N
245
35.66%
Air Raid
77
11.21%
AEM
25
3.64%
Mopar
36
5.24%
Volant
59
8.59%
Afe
32
4.66%
True Flow
7
1.02%
S & B
15
2.18%
Ram Hammer
9
1.31%
home made
113
16.45%
ebay or other (specify in a post)
69
10.04%
Voters: 687. You may not vote on this poll
Old 08-05-2015, 09:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Cold air intakes
Old 08-05-2012, 10:02 AM
DodgeBluto's Avatar
DodgeBluto
DodgeBluto is offline
It doesn't just give more fuel in WOT, it dumps more fuel thinking it is cold out. This is a bad idea, sorry no offence rocket. You will run rich all the time.
Running rich causes unburnt fuel and unburnt fuel can leed to clogged cats (meow), fouled O2's, washing cylinder walls, gas in teh oil which is bad for your internal bearings, etc....
No such thing as a free lunch.
  #302
Old 08-05-2012, 11:17 AM
Olerodder's Avatar
Olerodder
Olerodder is offline
I thought the computer keep the AFR at just over 14.?? all of the time except WOT
  #303
Old 08-05-2012, 04:45 PM
DodgeBluto's Avatar
DodgeBluto
I could be wrong I guess, but I though even at idle it gave more fuel as well. I just got into Dodges, but from my overall experience with cars cooler temps or the computer thinking it is cooler temps will feed more fuel.
Even if that is the case running rich isn't even good at WOT is it? Hence the term "running rich".
The point being, adding fuel will not give you power unless you add more air. When you go WOT, the computer puts you into a rich mode to take advantage of the increased air flow. So using an IAT mod will only add too much fuel causing you to clog cats and the other things I mentioned above. Messing with the IAT only is a bad idea, at best it could be a bandaide fix if you have a chronic lean condition.
  #304
Old 08-07-2012, 03:12 AM
rocket23's Avatar
rocket23
rocket23 is offline
Well I practice what I preach.....no problems yet, . But I'll keep an eye on the oil at change up.....might even go a step further and have it analyzed. Thanks for the info dodge.
  #305
Old 08-26-2012, 10:45 AM
dw8787's Avatar
dw8787
dw8787 is offline
Just installed an S&B CAI that was just released about a month ago. Nice fit and I think looks good. If I could get a pic to upload I would post one, but seem to be having problems doing that. Here is a link to the site which does have a pic. I got the oiled filter. I think they are having a few problems with the pics on the oiled version but the dry version pics seem to work. http://www.sbfilters.com/Intake-Dodg...-5-7L-75-5040D
Not sure about any gains. Not really going into it thinking I would have a seat of the pants gain. Wouldn't mind a little MPG help though!
  #306
Old 08-26-2012, 10:59 AM
dw8787's Avatar
dw8787
dw8787 is offline
Ok I think I got at least some pics to work.
  #307
Old 08-26-2012, 01:31 PM
08HEMI1500's Avatar
08HEMI1500
08HEMI1500 is offline
That's a nice looking kit but the filter seems a little small to me
  #308
Old 08-27-2012, 09:46 PM
dw8787's Avatar
dw8787
dw8787 is offline
It's actually pretty big. I think it might just look that way in the pic. It's every bit as big as a K&N, if not bigger. Look it up on the site. They've got better pics then mine.
  #309
Old 08-28-2012, 12:42 PM
willdikem66's Avatar
willdikem66
willdikem66 is offline
The Kit looks good, DodgeBluto has me thinking everything he says seems to add up but out of 3 trucks with a CAI i havent had to many problems that i could directly relate to the CAI
  #310
Old 09-20-2012, 11:25 PM
looka's Avatar
looka
looka is offline
Does anyone know how to make a homemade stage 1 CAI for the Hemi? What parts will I need?
Thanks
Quick Reply: Cold air intakes
