View Poll Results: What CAI do you have or recommend?
K & N
245
35.66%
Air Raid
77
11.21%
AEM
25
3.64%
Mopar
36
5.24%
Volant
59
8.59%
Afe
32
4.66%
True Flow
7
1.02%
S & B
15
2.18%
Ram Hammer
9
1.31%
home made
113
16.45%
ebay or other (specify in a post)
69
10.04%
Voters: 687. You may not vote on this poll
Old Aug 5, 2015, 09:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Cold air intakes
Old May 17, 2009 | 07:33 AM
  #51
RICOHDBIKER's Avatar
RICOHDBIKER
As Borat says: Very Nice, I like.
Old May 18, 2009 | 01:20 PM
  #52
dakota.on.fire's Avatar
dakota.on.fire
well, i have an ebay cold air intake, had one before on my trans-am too. personally i think theyre the best mod for the money, i mean it was 50 for the trans am, and it had like 3 or 4 foot of tubing to a really good place for an intake. the dakota cost 30 bux.
obviously the costlier ones cosmetically look better nad might have a slight difference in performance, i highly doubt ud feel seat of the pants difference. i don't even know if i did have the money if i would buy the expensive ones, maybe?!?! i don't care too much about engine cosmetics.
Old May 19, 2009 | 10:33 PM
  #53
butch1581's Avatar
butch1581
one last finished photo!
Old May 23, 2009 | 12:35 PM
  #54
blacktop's Avatar
blacktop
[QUOTE=butch1581;1666528]
Originally Posted by bwhite757
Sorry I didn't see this until now.
The heat issue has been discussed many times. Honestly only time will tell. Schedule 40 is rated for 140 degree liquid to run through it, air temps can probably be a little higher. So far my CAI has only seen a 90 degree day, and the Intake Air Temp reached around 105 (According to my Edge programmer). As long as my intake air temp doesn't get above 150, I'm not going to worry, right now it's solid, still looks good, and doing it's job...
What was your intake temp with the stock setup? How is the throttle repsonse compared to stock. Is it pretty loud?
You say your intake has only seen a 90 degree day how about the temps. under the hood especially when you shut the engine off. They are going to be way over 105 degrees. Use a temp gun on the out side of the intake and get real temps.
Also curious where are the intake air sensor fittings and the fitting for the hose that connects to the airbox when using the PVC method?
Old May 24, 2009 | 06:02 AM
  #55
MOPAR78's Avatar
MOPAR78
Heat has never been a problem with mine. The dual filter set-up is over 2 years old. It provided noticeable gains over the stock unit regardless of the heat issue. It simply flow's more air with the shorter tubes and extra filter. Saved money too by home-brewing.
Old May 25, 2009 | 10:39 AM
  #56
TheFist's Avatar
TheFist
Thats a pretty killer intake!
Old May 27, 2009 | 12:07 PM
  #57
butch1581's Avatar
butch1581
[QUOTE=blacktop;1676790]
The Air temp sensor is right in the middle of the 90 degree fitting, just drilled a hole and rtv sealant! I removed the hose you are talking about and installed a minifilter on the end of the little pre-bent hose.
Old May 28, 2009 | 11:45 PM
  #58
davb673's Avatar
davb673
Wow. Nice work MOPAR78. Mine is not so pretty, but it seems to work. I did the homebrew route and am using an AMSOIL filter inside the factory box. I may redo it sometime this year, if I get around to it... It does sound much better than stock when I drop the hammer. MPG change? I don't know, as I did this shortly after getting the truck.
Old Jun 9, 2009 | 08:02 PM
  #59
joe44473's Avatar
joe44473
I have recently got a K&n cold air intake 63 series Id like to know other peoples result with this one or other K&N intakes. I hav a flowmaster dual exhaust as only mod. How has cai changed your truck
Old Jun 9, 2009 | 08:18 PM
  #60
chambers's Avatar
chambers
Pretty much all the cold air intakes give you 8-10 hp and better throttle response as long as they eliminate the stock tubing to the throttle body.
