Superchips Questions and Updates
Old Apr 20, 2012 | 03:03 PM
  #3351
ledyard's Avatar
ledyard
04 2500 hemi 35" rubber, 4:56 gears. Cortex
How much will the 87 tune lower my mpg city hwy ect..?
Old Apr 25, 2012 | 12:28 AM
  #3352
Dead2Fall's Avatar
Dead2Fall
Superchips is offering a $50/25 mail in rebate guys. Use that tax money!!
Old May 5, 2012 | 10:23 AM
  #3353
areinike's Avatar
areinike
Default Trick in getting superships to program '03 4.7L
There has GOT to be a better way to get a tune in this thing. Here's what I had to do to get it going ... not sure which part actually did the trick.
Pulled the PDC and cleaned ALL of the contacts and reinstalled. Pulled connectors from the PCM and cleaned all of THOSE connectors. Cleaned the OBD connector - all with electric contact cleaner.
Brand new battery by the way, about 2 months old ... hooked up battery charger and set it to manual at 10 amps charging rate. (highest without going to 60 amp starting mode)
Found a sacrificial chicken and beheaded it. Don't worry, chickens are good eatin'
Must have repeated the tune cycle about 12 times and FINALLY it took. Tuned it with 87 tune. Seems that once it's in, it works perfectly fine. It backed up my stock tune, flashed the 87 tune and done.
Any tricks or ideas?
For giggles, tried it again shortly thereafter and no dice. It's very finnacky at best to get this to flash.
I've heard of issues flashing the '03's but by now, I would think there HAS to be a way to get it to "glitch" in easier. Maybe a localized battery attachment somewhere for a little more power to get in there ... who the heck knows.
Maybe some sort of sequence that works better, turning the ignition on/off timing wise .... fuses pulled, etc.
Old May 5, 2012 | 10:35 AM
  #3354
areinike's Avatar
areinike
Oh, here's one thing I learned. You don't have to wait 20 minutes each time for it to fail. Once you turn the ignition on for the tune, if it doesn't come up with the tune menu within 30 seconds, try again. My Flashpaq actually started to blink a few times almost right away and then presented the menu when it finally went through. But if you're stuck at the Please Wait ... for any longer than 30 seconds, it isn't going to work after 20 minutes.
Old May 21, 2012 | 11:35 PM
  #3355
Ellis42's Avatar
Ellis42
Someone told me that there is no Trans Tune available for the 02 Dodge Ram 1500
Is this true?
Old May 21, 2012 | 11:38 PM
  #3356
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^ Correct. 04+ only for SC. Diablo is 05+
Old May 22, 2012 | 01:15 PM
  #3357
Ellis42's Avatar
Ellis42
Son of a b!tch.....oh well
Old May 25, 2012 | 03:50 PM
  #3358
Ellis42's Avatar
Ellis42
Ok another stupid quiestion but I heard you can't log data for the 02 Dodge Ram 1500
Is this also true?
Old Jun 22, 2012 | 08:51 PM
  #3359
jcb36's Avatar
jcb36
Default Daytona bouncing off rev limiter from a roll
I've emailed, posted, and called SC settings and am getting no customer service. I constantly bang the limiter at a role I guess its the 2-3 shift ...rolling at say 55mph and stomping on it..hits limiter. I've tried 5900, 6000 at 6300..she bangs..5900, 5950, at 6200, she bangs....currently at 5900, 5800, at 6300 she bangs..05 daytona ..HELP!!!
Old Jun 25, 2012 | 08:17 PM
  #3360
dirtydog's Avatar
dirtydog
Moderate User
You sound like William Hung on American Idol.....rofl
http://video.search.yahoo.com/video/...+2004+audition
If you have Advanced trans tune, sounds like you have excessive overlap between gears.
