Diablo Information and Reviews
02-10-2012, 01:19 PM
on
Quote:
Originally Posted by
T-Muns
Returned to stock then installed 91 tune and reset pcm - no change. Still stops the throttle at 4500 in second gear.
did u play with wot shifting or drive rev limit ?
02-10-2012, 01:22 PM
adventurer
Just got this thing and first installed 93 tune and 91 per your instructions. I did install the calibration update because I had to in order to tune.
Otherwise, haven't changed any settings and have never had throttle or trans issues.
02-10-2012, 01:27 PM
on
T-Muns
can u check the wot 2-3 shift on what rpm is set ? its under modify tune menu
02-10-2012, 01:38 PM
adventurer
I don't have shift options (maybe because I have 03?). Under 91 tune -> Modify Tune, I have Tire Size, WOT Fuel, and WOT Spark.
02-10-2012, 01:42 PM
on
T-Muns
no rev limiter or wot shifting , so u don't have trans menu under the modify tune ?
02-10-2012, 01:46 PM
on
adventurer
trans not supported on the 03
adventurer
Nope.
02-10-2012, 01:57 PM
on
T-Muns
Nope.
keep on checking ur post at diablo sport forum, they will help u . Good luck
02-10-2012, 02:09 PM
adventurer
Thanks, will do.
02-17-2012, 07:52 PM
on
So the other day I finally got my DSP calibrated and the crom updated. Put in the 91 tune and WOW!! I love it. I hit the gas and that engine woke up from a deep sleep like a bat out of hell. Barely touching the gas and thowing you in the back of the seat. The best $200 I have ever spent. One of these days I will put in a higher octane gas just to play with 93 tune. Thank you DSP!!
