Diablo Information and Reviews
Old 05-23-2010, 04:37 PM
RedTruck-VA's Avatar
RedTruck-VA
RedTruck-VA is offline
Originally Posted by ak_hemi
I've got the Dodge 20 in wheels with the good year wranglers on them, and I think the gears are 3.92s because according to the inside of the drivers door the truck originally came with 17s.
I don't like the tires at all except that they haven't given me any trouble and there is still at least 10-15k worth of miles on them.
I was thinking of downsizing back to the 17s and getting E rated tires for stability. Do you think that will help with mileage? Or do you think that changing gears w/ the 20 in wheels is a better idea?
thanks for the advice!
From what I have seen, 20's usually come with the 3:92 and 17's with 3:55. eFan is a good move and will give a touch of performance. Gears seem to be the one thing that makes a big difference. The sweet spot for our hemi's is around 2100 rpm at highway speed. So if you can gear for that you will see mileage and performance increased. I run 30.25 inch tires and with a 4:10 gear turn 2000 rpm at 65 mph. Still get 15-16 mpg with a 2800 stall TC. (on the highway with the TC mostly locked)
  #642
Old 05-23-2010, 06:37 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
At 70 mph im turning 2000 rpm with 456s and 36" tires
  #643
Old 05-23-2010, 08:59 PM
RedTruck-VA
Weed, good input.... tire size make a hugh difference.
  #644
Old 05-29-2010, 07:21 PM
RedTruck-VA
This thread is dead...
Ok, I just started using a DSP. To start with I have had no previous ABS issues. A few days ago I installed a DSP tune and my ABS amber light stayed on a little longer than usual and cleared when I moved my truck. Today I installed another tune and on startup I heard a little louder clunk from what I would guess was the HCU under the truck. Well the ABS amber light has not cleared. I have re-installed the stock tune, didn't help. Re-installed the DSP canned tune, didn't help. Pulled the PCM fuse, didn't help. Dis-connected the battery, didn't help. Brakes feel the same as before getting the light. The ABS amber light has an unsteady blinking sequence. I feel this is related to using the DSP. Anyone experience anything like this? Any suggestions?
Thanks,
  #645
Old 05-29-2010, 07:27 PM
SilverBullet08's Avatar
SilverBullet08
SilverBullet08 is offline
yea ive read thats a known problem with dsp...
  #646
Old 05-29-2010, 07:43 PM
RedTruck-VA
Great, I think... Is there a solution?
I must have missed that in the advertisement lol
  #647
Old 05-29-2010, 10:02 PM
glass3222's Avatar
glass3222
glass3222 is offline
with your dsp, have you looked under diagnostics for any codes? I have not heard of or had this issue with mine. Also, have you looked at diablo's forum to see if anyone has had this issue and how it was resolved?
  #648
Old 05-29-2010, 10:34 PM
RedTruck-VA
Glass, This was a recognized problem with the dr03 firm ware and supposely was solved with firm ware upgrade dro4. I had dr04 firm ware installed in my DSP. I reloaded the original tune and then upload the latest firm ware tonight and will see what happens tomorrow.
  #649
Old 05-29-2010, 10:46 PM
glass3222's Avatar
glass3222
ok. hope that works for you. I'll have to see what firmware I have.
  #650
Old 05-29-2010, 10:58 PM
RedTruck-VA
Also, I'm not getting any codes, just the ABS amber warning light flashing in an uneven sequence.
Quick Reply: Diablo Information and Reviews
