Diablo Information and Reviews
Old 08-03-2010, 12:18 PM
AWE Daniel's Avatar
AWE Daniel
AWE Daniel is offline
Originally Posted by butch1581
more than likely the cruise not working has nothing to do with the diablo. try loading your stock tune.....I bet it still wont work
LOL This made me laugh. Every time I go on a trip I load up the stock tune and cruise all day. Try looking on Diablo's own forums, it happens to a lot of people.
  #722
Old 08-08-2010, 09:38 AM
RedTruck-VA's Avatar
RedTruck-VA
RedTruck-VA is offline
Default PCM reflash problem
03 ram 1500 SXT-Hemi
Short story, installed the DSP U7137 and tried to adjust my tire size using "Quick Adjust" and threw a ABS warning light. Diablo was no help and I restored the original tune and took it to the dealer and had the PCM updated and ABS reset. The dealer said they were unable to install the new PCM version number. Re-installed the DSP with an updated Crom, Used "Quick Adjust" to set tires and got a ABS warning light again. Took it back the dealer to reflash PCM and reset ABS. Dealer says the Diablo tuner has my PCM elocked making it impossible for them to properly reflash. Does Diablo leave residual code in the PCM even after restoring original tune? What does it take to completely un-install the Diablo?
My question is; Has Diablo screwed up my PCM preventing the dealer from reflashing or is the dealer blowing smoke?
Getting a weee bit frustrated with this.....
  #723
Old 08-08-2010, 01:19 PM
AWE Daniel's Avatar
AWE Daniel
I think the dealer is blowing you off. Sometimes they refuse to touch a vehicle if they know that it is modded, they don't wanna be responsible for anything. A computer is a computer, if the PCM software is somehow corrupted/locked, they can run a master reflash, no matter what.
As for your abs problem, have you tried taking the truck to the dealer with the factory tune on it and having them adjust the tire size? It would be interesting to see if that causes an ABS light.
  #724
Old 08-08-2010, 01:20 PM
truckin151's Avatar
truckin151
truckin151 is offline
The dealers flash will override any programmming that is in there from any tuner,
  #725
Old 08-08-2010, 03:03 PM
RedTruck-VA
This is what I am hoping for, but not sure they have the ability.
Both times I have taken the truck in it has had the factory tune installed. I didn't want them to mess with the tire size, but they made the adjustment and got it 3 mph off. I told them to put the tire size back, but it wasn't change.
Maybe I need another dealer, this one doesn't seem to be able to get the reflash done. I'm meeting with the service manager tomorrow.
  #726
Old 08-10-2010, 05:59 PM
RedTruck-VA
Update: Haven't got the new SC3865 installed yet but been on the phone with SuperChip several times this afternoon working on the problem. Occassionally it comes up which tuner should I buy, and I will suggest before deciding contact the their individual tech support folks to see how accessable they are just in case you have a problem. That in it self will tell you all you need to know to make an informed decsion.
  #727
Old 08-18-2010, 10:52 AM
delinpa's Avatar
delinpa
delinpa is offline
I too am on the fence about which programmer to go with. I got information on the hp gains from both SC and Diablo. I was told the Superchips will give me 18hp / 26tq on my 2010 5.7l Ram (on the 91 Octane program), and the Diablosport U7137 is supposed to give me 25-30 hp. Anybody have a feel on this? My only changes on my truck are an AFE filter and Flowmaster Super 44 muffler.
Thanks,
Doug
  #728
Old 08-18-2010, 12:55 PM
AWE Daniel's Avatar
AWE Daniel
Diablo will work well for a 2010 because it has all the features superchips has and a few more, and will accommodate custom tuning if you go for a cam or something down the road.
  #729
Old 08-19-2010, 11:18 AM
delinpa's Avatar
delinpa
delinpa is offline
Will the Diablo really give a 25-30 hp gain, or will I have to do other mods to reach that hp? I want as much hp as I can get, but don't want to do any internal mods to the motor. Superships will only give an 18 hp gain.
Thanks!
  #730
Old 08-19-2010, 11:46 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Go and add your location and trucks info to your profile. If you are close to me I can help you or do the cam install for you. Its not hard but it takes time.
As for that 25-50, Im sure that would be at the crank and not at the wheels
Quick Reply: Diablo Information and Reviews
