Diablo Information and Reviews
Old 02-08-2011, 11:21 AM
Rich 2500's Avatar
Rich 2500
Rich 2500 is offline
anyway, the first on starts of @15
Are you sure it's 15 and not 1.5? I don't think the kn sensors should not let it get that high.
  #882
Old 02-08-2011, 07:17 PM
05akram's Avatar
05akram
05akram is offline
Ok I went out and hooked up everything again. No lab top so sorry I just recorded everything and wrote it down.
@Idle they read
KNK LT RETARD deg.---0
KNK ST RETARD deg ---0
KNK Sensor 1 Voltage---.1 (moves a little)
KNK Sensor 2 Voltage---.12-.13 (moves a little
Actual SPK Cyl 1-------15-18
Then I went and took it for a dirve and got on it since the LT and ST are at @0
KNK LT RETARD deg ---0 never showed any
KNK ST RETARD deg ---0 never showed any
KNK Sensor 1 Voltage--- .6
KNK Sensor 2 Voltage---.6
ACTUAL SPK CYL1 deg--- 36
Im guessing Im OK since the LT and the ST RET didnt move any...Is this correct? Thanks for your help.
  #883
Old 02-08-2011, 08:08 PM
Rich 2500's Avatar
Rich 2500
OK, that's about perfect.
  #884
Old 02-08-2011, 11:59 PM
truckin151's Avatar
truckin151
truckin151 is offline
Yep that is what you want to see. Dont want to see the ST KR go past 3*-4*
Was that just sitting at idle or was that driving?
  #885
Old 02-09-2011, 12:08 AM
05akram's Avatar
05akram
05akram is offline
Thanks guys. That great news. The first set of numbers was idling and the second was under a full throttle pass..Not that it happened but is it ok to see a 1* or 2* knock at shift as long as it goes away quick?
  #886
Old 02-09-2011, 12:50 AM
truckin151's Avatar
truckin151
Its alright but 0 is what you want it to be obviously. If 1*-2* pops up and doesn't build it could be the knk sensor picking up some noise from something else. Nothing to really worry about til it hits the 3*-4* mark and is consistant in under the same circumstances and builds once it happens
  #887
Old 02-10-2011, 11:42 AM
Rich 2500's Avatar
Rich 2500
Just a bit of Info to pass on, Diablo did make the Kn sensors less sensitive on Rev. 9R06crom up, so they get a lot less false Kn than they did stock.
  #888
Old 02-10-2011, 10:23 PM
truckin151's Avatar
truckin151
That was really only for the 4th gens as they were having the most issues with the KR under part throttle on earlier revisions.
  #889
Old 02-11-2011, 12:17 PM
Rich 2500's Avatar
Rich 2500
No, not only 4th Gens, I was in personal contact with Johan (sp) at Diablo, because after I downloaded the CROM I no longer showed any Kn, and I had always show 1-2 on Kn ST, I was afraid that I had lost that function on the new download. Johan informed me that they reduced the sensitivity of the Kn sensors, and ask if I was showing anything on the KNK Sensor Voltage, I was, so that satisfied him that it was still functioning.
I was thinking it was 6, but it may have been 4 or 5, revisions were coming pretty close together back then.
  #890
Old 03-02-2011, 05:52 PM
frenchbee2306's Avatar
frenchbee2306
frenchbee2306 is offline
hey
anybody here with a '05 hemi ram and DS Trinity or Predator ?
I got the Trinity, everything works fine but I cannot get shift points parameters adjustments
who has that same issue please ??
thanks
Quick Reply: Diablo Information and Reviews
