Diablo Information and Reviews
#971
I have the procharger and I am hoping to find someone with a dyno to get this thing dialed in, but the local place I talked to did not sound too confident in dealing with it. I would be willing to drive the truck wherever as long as somebody knows what they are doing. THanks for the input.
#972
Shoot HemiFever an email and see if there is anything he can do with the tunes he writes. I know within 3 rounds he had my cam dialed real good. A dyno tune would be best but I think you are going to find those are few and far and quite a bit more costly.
http://www.hemifevertuning.com/
#973
I notice from your signature that you went down to a lower tire size. Did diablo compensate the speedometer when you told it your current tire size?
#974
Yep showed the guys there what it needed and they grabbed the parts off the shelf. It should be nice cause it'll have all the partial up shifts and down shifts and I have a setup for the partial shifts that a lot of the guys on another forum have been raving about since it came out. I'm gonna finish grilling and then I'll get it all looked at after dinner.
What all will it data log?
#975
No, your 07 only has partial upshifts so my shift schedule wouldnt work with your truck. 03-04's have no trans control, 05-06's have partial upshifts and downshifts, 07'+ only have upshifts. Since mine is an 05' I have mine setup to work with my downshifts so it wont work.
#976
#978
Thanks for the clarification. Does anyone have any upshifts for the 07 and up? Has anyone have the DSP with a STS turbo kit? Thats where I am going.
Yes it lets you adjust the tire size which adjusts the speedometer. Our Speedometer is based on the tire size not the rear dif.
#979
just need to figure out where the trans settings can be found on the diablo predator the manual says it's under quick adjust but it's not so i'm not sure where you can adjust them at.
thanks
thanks
